Trans pan torque? - Chevy and GMC Duramax Diesel Forum
post #1 of 4 (permalink) Old 08-07-2009, 07:04 PM Thread Starter
jscribn1's Avatar
Trans pan torque?
I just installed my Allison deep pan and was wondering what the specs might be for the transmission pan bolts. Does anyone have that info handy? Thanks.
jscribn1 is offline
post #2 of 4 (permalink) Old 08-07-2009, 07:30 PM
Crusher's Avatar
I copied this from my Aftermarket Deep Aluminum Pan Instructions;
Torque Specs
Pan Bolts 15 lbs-ft
Pan Drain Plug 20 lbs-ft
Sensor Plug 12-15 lbs-ft
V/B Bolt 8-10 lbs-ft
2006 Chevy 2500HD LT CCSB 4X4 Duramax LBZ;
EFILive V2 Tuned by IdahoRob, FASS HD-C10-150G,
BANKS Ram Air Intake + Super Scoop, Banks Boost CAC Tube, BD Exhaust Manifold, EGR Blocker, MBRP DP, 4" Turbo-Back Exhaust w/ Aero-Turbine 4040, PCV Reroute, Transgo Jr., B&M Racing Deep Pan, Pure-Power Filter, SunCoast Deep Filter Lock,
Autometer Ultra-Lite II - EGT & Boost in overhead. NCT/Bilstein Shocks, Sulastic Shackles, Kryptonite Tie-Rods, Cognito UCA & Steering Braces, Firestone Ride-Rite Airbags, Reunel Bumper, Open Country M/T, LINE-X, TruXedo Tonneau, Pro-Tech Toolbox, Pioneer FH-P8000BT, i-pod, Focal 165KF Frt & Rear, JL Audio 300/4 Amp, Focal 27KX Subs, Audison Amp, Rattle-Trap Xtreme.
Crusher is offline
post #3 of 4 (permalink) Old 08-07-2009, 07:46 PM
HuskerDiesel's Avatar
15-20 ft/lb... X2^^
start on the middle of the sides and work front to back front to back front to back and so on....
HuskerDiesel is offline
post #4 of 4 (permalink) Old 08-07-2009, 08:10 PM Thread Starter
jscribn1's Avatar
Got it done thanks guys!!
jscribn1 is offline
