Torque converter problems!!!!! - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 09-13-2009, 04:21 PM Thread Starter
Lawnjockey's Avatar
Just bought my first duramax Tuesday and now it broke down with what we think is a bad torque converter... Had a 2500 gas and trans temp would climb to 200 pulling 4k daily and thats with 2 coolers. So I traded like an idiot an bought a 03 gmc 3500 dually with allison. The day before it broke down the temp went up to 190. (a foreseen problem, maybe in both trucks?) I still think that it will be a much better truck that just needs a few kinks worked out of it... I talked to the dealer(small car lot) and he said that he would like to fix it for me.. Should I be scared of their mechanic or let them try and make it up to me? I know you can't put anything but an allison replacement in it, can you?
Lawnjockey is offline
post #2 of 9 (permalink) Old 09-13-2009, 05:06 PM
Slave to the Interwebs
Johnasara's Avatar
What makes you think it is a bad converter???? I do not know if I would trust a little mom and pop used car dealer working on my truck either. Look into buying a suncoast or equivilant converter they do not cost much more than a stock one and will handle a lot more abuse
Ohh and I moved your post so it will get a little more veiwing.BTW welcome to the site and good luck.
Johnasara is offline
post #3 of 9 (permalink) Old 09-13-2009, 05:07 PM
Its just a worktruck
DMAXchris's Avatar
190 is not high. That is normal operating temp. And yes, you can replace to converter with an aftermarket one.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
post #4 of 9 (permalink) Old 09-13-2009, 05:09 PM
Why don't you like the Allison? What Happened to it?
Dmax-man is offline
post #5 of 9 (permalink) Old 09-13-2009, 06:11 PM
Administrator
jc1843's Avatar
It is normal to run 200 degrees towing around town-- The converter makes a lot of heat because of the stop and go driving-- What else is wrong!
jc1843 is offline
post #6 of 9 (permalink) Old 09-14-2009, 12:26 PM Thread Starter
Lawnjockey's Avatar
Thanks for the move John. Thanks for the input. I had a loud rattle and then the next morning while going to the dealer I heard a loud noise like a air hose busting loose and then no power. Engine would run but it was loping at around 300rpm. Put it into D and would not do anything. My regular tranny guy says whe I got to his place that it sounds like converter. Talked to dealer and they are sending it to a tranny shop that apparently are good. I will go by there tom. Don't get me wrong, I gave up a good running 2500hd for a d-max. I don't regret it, yet... I have a lawn bus. and also I have a 10k fifth wheel. It should do fine... Good to see that 200 deg is ok for local towing, but how about hwy? Put it into tow mode?
post #7 of 9 (permalink) Old 09-14-2009, 04:52 PM
duratothemax's Avatar
whats wrong with 200 degrees......................................? Seriously...allisons generally run ~100* over ambient temperature. Its normal. Dont worry about it.
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
post #8 of 9 (permalink) Old 09-14-2009, 06:04 PM
Administrator
jc1843's Avatar
This sounds like you blew a inner-cooler boot off. Inspect the lower boot by the power steering gear.
jc1843 is offline
post #9 of 9 (permalink) Old 09-16-2009, 01:00 PM Thread Starter
Lawnjockey's Avatar
Well looks like it is the torque converter and front pump are out....Dealer says they are ordering parts to fix...Looks like here in Tn. we have a 30day lemon law and this is covered under it so they should be making good on the repairs...
