Gear Vendor - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 09-29-2009, 03:49 PM Thread Starter
Gear Vendor
Does anyone know about a gear vendor for an allison 1000?
ferdkilla is offline
post #2 of 8 (permalink) Old 09-29-2009, 03:52 PM
That One Guy
WisconsinHick1's Avatar
Do you mean a transmission guy to rebuild the allison 1000?
Green Bean Out
The Rag In
Built With Help From Some Great Friends and Sponsor Jags Pro Truck Shop!
WisconsinHick1 is offline
post #3 of 8 (permalink) Old 09-29-2009, 03:53 PM Thread Starter
no a gear vendor under/overdrive unit.
post #4 of 8 (permalink) Old 09-30-2009, 07:05 AM
They called me looking for an adapter for a truck they were building for Mothers Automotive Products but I haven't heard anything lately and it had an Allison in it with there unit on it
allisondan is offline
post #5 of 8 (permalink) Old 09-30-2009, 07:14 AM
Buck's Avatar
advanced adaptors will make you one for anything. but i doubt that allison has anything with an oem p/n on it.
Vehicle 2008 Black Chevy Crew Cab Short Bed Z71
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods EFI Live and DSP 5 By MMLMM, RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Titan 52gal fuel tank, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline
post #6 of 8 (permalink) Old 09-30-2009, 08:00 AM
gr8shot's Avatar
Why do you need it? The 5 speed allisons have about the ideal rpm range for mileage and pulling power once you do like most and go larger with tires. The 6 speed runs too low of rpm's once you put bigger than stock tires on it. Lowering the rpms just lugs the motor. It will run higher boost, which uses more fuel.
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #7 of 8 (permalink) Old 10-01-2009, 09:07 AM Thread Starter
didnt say i needed it. was curious if there was one made.
post #8 of 8 (permalink) Old 10-01-2009, 09:25 AM
gr8shot's Avatar
touche! Well FWIW, I don't know if they make one or not. Suncoast makes a 6 speed conversion kit, but its expensive for what little if any benefit you get.
Jesse
2004 LB7
Tastefully modded
Lots of miles
gr8shot is offline
