4wd max speed? - Page 2 - Chevy and GMC Duramax Diesel Forum
 3Likes
post #11 of 39 (permalink) Old 10-06-2009, 09:30 PM
20mph? what the hell are you talking about??? the speed limit in snow, with or without 4wd, here in NV is 35. Why in the world would you feel unsafe at 25, 30,or even 40 in snow? He didn't say he was tailgatin', or on a winding mountain road. Yeah, it's nutty to do 70 in the snow (did 75 once, a real thrill, but stupid), but it's almost as nutty to say 20 is the max safe speed.
If I was following you doing 20 in a snowstorm, I would assume you had never driven in the snow in your life, and you must be frozen in place by fear.
Of course, that is just my opinion.
buckmeister2, carson city, nv, 2004 dmax lb7 4x4,ext. cab LT SB, loaded, 3.73 rear, 168,000 miles, Banks 4" turbo-back pipe, no cat, HUGE muff + AirRaid CAI (both PO install), Mild ECM program by IdahoRob , Rollover ball gooseneck hitch for towing '09 Cougar 5th wheel, 35', 10,600 pounds
buckmeister2 is offline
post #12 of 39 (permalink) Old 10-06-2009, 10:37 PM
maxxflip's Avatar
Driving in the snow how fun :LMAO
06 LBZ
LMM RIP 10/9/10
maxxflip is offline
post #13 of 39 (permalink) Old 10-07-2009, 12:16 AM
Oldvintageiron's Avatar
Buckmeister2 I guess you didn't understand my post. I did not say not to drive over 20mph in the snow(how stupid) I said I don't drive over 20 in 4wd. Above that I take it out of 4wd and drive as fast as I wont. It's hard on shit in 4wd especially when there is not enough snow on the ground. I only use 4wd to take off I don't need 4wd to stop thats what my brakes are for. And really if your one of thoes guys that do drive 70 in 4wd WHY. Does it make you feel safe.
Of course, thats is just my opinion.
2004.5 lly GMC CCSB 2500
Stock LBZ intake, AFE MP, Afe IC Tubes both sides, MBRP DP w/ heat wrap
BD manifold, EGR block plate, Banks turbo back(no cat) ,coolant bypass filter
EFI Live by IDAHOROB w/DSP5http://www.atptrucks.com
Aeroforce Interceptor gauges, ARP studs,
19.5 Rickson wheels W/ 225/70/19.5 drive/ steer
BD Flowmax Lift pump, auxiliary fuel filter PPE fprv shim
Bullydog shift enhancer/ Amsoil Race Trans Fluid, MA pump rub fix.
Amsoil Bypass Filtration, Amsoil 3000 5w30 oil
Cognito Motorsports Pitman/ Idler support kit,Secondary Radiator system built by me
Oldvintageiron is offline
post #14 of 39 (permalink) Old 10-07-2009, 12:54 AM
Banned
Originally Posted by Oldvintageiron View Post
I dont run mine over 20mph. If you fell you need 4wd to go above 20mph you shouldn't be driving that fast. If you need 4wd to go 50 let alone 70 how are you going to stop? Driving on the drag strip is different.
so i should be going 107mph in the 1/4 in 4wd? I have gone 200 miles from the dunes in 4hi and not one issue.
How and i going to stop in 4wd? simply push on the brakes
how is driving on the strip different? 4wd is 4wd it doesnt know the difference.
Hondarider552 is offline
post #15 of 39 (permalink) Old 10-07-2009, 09:45 AM
When you turn in 4wd it binds- I said driving on the drag strip is different your not turning. Hollyshit people. Just drive your truck how you want. Just don't complain when your shit vibrates.
Good thing your a tech, I hope you don't talk that way.
post #16 of 39 (permalink) Old 10-07-2009, 09:55 AM Thread Starter
petal to the metal, playing footsie with fate.
just my oppinion
2004 Duro
PPE Standard programmer
K&N drop in filter
Stock straight pipe
duroforshuro is offline
post #17 of 39 (permalink) Old 10-07-2009, 09:56 AM
maxthis's Avatar
Send a message via Yahoo to maxthis
Holy crap......a little sensitive are we?
I believe the original question was how fast you can drive in 4wd. Not how fast does everyone feel is safe to drive in snow. Your truck won't mind, I just woudn't suggest taking it in or out of 4wd anything over 35mph.....
Anyone throw it in or out at higher speeds without ill effects? I take that back...I have probably taken mine out at 50mph but not engage.
04.5 LLY
-68mm Cheetah w/ 4" dp
-DSP5 and G-Max5/1058 by Fleece Performance (473/871)stock turbo
-Leveling kit, 33" ATZ's 18" Ultra Predators
-shim kit, egr and resonator blocked
-Cognito Braces, PPE tie rod sleeves,60" traction bars
-4" banks turbo back and 5" MBRP miter cut stack
-AFE mouthpiece, K&N Stainless intake, AirDog 150
-Cowl hood, spray in bed liner
maxthis is offline
post #18 of 39 (permalink) Old 10-07-2009, 10:07 AM
Banned
welcome to the forum, noob. stay awhile and learn a thing or two.
post #19 of 39 (permalink) Old 10-07-2009, 10:12 AM
Chevy*tough's Avatar
Send a message via Skype™ to Chevy*tough
Well i thought we were talking about using it in a snow storm???
sorry for the HI JACK
But how did it go from high speed 4wd to snow storms??
My 01 duramax LB7 AMSOIL Equipped, 200,xxx miles, 4in stainless w/7in tip, ISSPRO GAUGES, HIDS high and low, tow mirrors, ported mouthpiece, AFE stage2
265 nittos on Helo maxx8 black. 4th limp
EFI LIVE THANKS TO: Kory at PPEI
Donovan
Gamertag: dirtymax01
SYNTHETIC MOTORSPORTS
Chevy*tough is offline
post #20 of 39 (permalink) Old 10-07-2009, 10:16 AM
Its just a worktruck
DMAXchris's Avatar
Yes. Mine is on the floor though. I did it on the highway a few times. I put it in N, crammed it in 4HI, put it back in D and was pedal to the metal.
I have to put mine in 4HI in the rain sometimes. Either that or baby the go pedal.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
