Old 10-19-2009, 06:13 PM   eBay Motors   #1 (permalink)
midieselguy
midieselguy's Avatar
Deep Pan upgrade
I just put the Hughes Supply deep pan on and WOW. I've easily dropped 40 degrees just on highway driving. What prompted this was pulling 8,000 lbs up the grade from Phoenix, AZ to Flagstaff. This is a climb of roughly 5,000 feet with most of the climb in 3 short sections. I had the tranny up to 235 degrees.
I'll be pulling the grade this weekend to see the improvement to the tranny with this upgrade.
The Hughes pan is a +4 pan, aluminum with fins. I'm expecting great results.
2004.5 LLY, X-Cab, short-bed, Allison Trans, 4" MBRP Turbo-back, no cat, KB's IOH kit, EGR block plate, no finger stick, MB Razor 16x8 with BFG AT 285's
midieselguy is offline   Reply With Quote
Old 10-19-2009, 06:18 PM   eBay Motors   #2 (permalink)
JuniorDiesel
JuniorDiesel's Avatar
Very curious to see what improvement you get since I too pull a large trailer and would like to keep those temps at bay.
2007.5 Silverado 2500HD LMM
Edge Evo CTS
MBRP 4" DPF back exhaust, H.I.Ds, Billstien 5100's ON THE WAY
AMSOIL
http://www.lb7.info/
http://www.syntheticmotorsports.org/
Toys:
2008 38' Heartland Cyclone Toyhauler
2008 Raptor 700R - FCI intake, DRD exhaust, PCV
JuniorDiesel is offline   Reply With Quote
Old 10-19-2009, 06:20 PM   eBay Motors   #3 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
your guage is lying to you.
deep pans do not lower transmission temperatures, they only take longer for the fluid to warm and slower for the fluid to cool.
Old 10-19-2009, 06:23 PM   eBay Motors   #4 (permalink)
midieselguy
how is the guage "lying to me" There's a temperature probe in a fixed location measuring the temperate of the ATF as it passes that position. Seems to me, if it's reading 130, then the fluid is 130'ish
Old 10-19-2009, 06:25 PM   eBay Motors   #5 (permalink)
Hondarider552
OEM trans probe is in the valvebody, not the pan, there is quite a bit of difference between the two.
lets just say 150* on oem cluster isn't 150* pan temperature.
Old 10-19-2009, 06:26 PM   eBay Motors   #6 (permalink)
WisconsinHick1
WisconsinHick1's Avatar
Yes but like Brian said it takes longer to warm up and longer too cool down so if you where driving 40 miles before the new pan and you where seeing 160'ish and with the new pan you see 130'ish it is taking longer to warm the extra fluid up.
A FEW MINOR UPGRADES
Tuned by MMLMM
SC V
Old 10-19-2009, 06:29 PM   eBay Motors   #7 (permalink)
Hondarider552
A true test would go 200+ miles up to flagstaff and back pulling max GVWR. i bet you wont see a difference.
Old 10-19-2009, 07:35 PM   eBay Motors   #8 (permalink)
Chazm107
Chazm107's Avatar
i agree, i only noticed the same results of longer warm up and cool down times but i think it is beneficial to have the extra fluid in there
05 Silverado Crew Short Bed LLY,6" superlift, 22" dubs
35" nitto Terra Grapplers AT,AFE Stage 2 W/pro guard 7
Lbz mouth piece,fuel Rail shimmed,5" Mbrp turbo back cat delete with 6" tip
Diamond eye down pipe
Autometer phantom gauges, trans go shift kit
Mag hytec deep trans pan, BD manifold, egr blocked no fingerstick
Pcv reroute,PPE standard, kennedy diesel boost stick
Chazm107 is offline   Reply With Quote
Old 10-19-2009, 08:22 PM   eBay Motors   #9 (permalink)
subparwelder
subparwelder's Avatar
I've noticed a solid 20deg drop in temps pulling with mine this summer. He's right about the temp difference from the factory probe to the bottom of the pan. I have a mag pan with a probe and temp gauge and the fluid in the bottom of the pan is always 10-12 deg cooler than up by the factory probe or dic display. Can't say its the best 300 stones i've spent but having a bigger internal filter and more fluid can't be a bad thing. Oh yea and it looks bad ass too.
08 GMC SIERRA SLT CREW SHORT BOX Z71
6'' BDS LIFT 20'' KMC XD HOSS'S W/33'' TERRA GRAPPLERS
5'' TURBO BACK MAGNAFLOW STRAIGHT PIPED
EFI BY IDAHOROB
TRANSGO JR AND MAG DEEP PAN
ALL AMSOIL FLUIDS
subparwelder is offline   Reply With Quote
Old 10-20-2009, 04:34 PM   eBay Motors   #10 (permalink)
jhnttrpp
jhnttrpp's Avatar
Subpar you said your oil is 20 degrees cooler than before you put the new pan in, that means it is working. You also mentioned that the oil in the valve body was cooler than the pan. Adding more fluid and putting fins on the pan will reduce your oil temp. It's one of the reasons Diesel engines have so much larger engine oil sumps. You have inspired me to look into getting a larger pan. I pull a heavy fifth wheel camper and tranny temps get up there on long climbs but comes right back down when it levels out. thanks for the info.
2006 Silverado CC SB 2500 Duramax LBZ I drove it 42000 miles the first year. I don't know where I went.
jhnttrpp is offline   Reply With Quote
