Originally Posted by ynotracing2221 Sounds like your clutchs are toast if it keeps on going into limp mode even without a tune. Time to build your tranny! Thats just my .02. Maybe Mike L will chime in and give you some other info. |
Output Speed Sensor.
You may have a wiring problem at the speed sensor ( in the transfer case on a 4X4, in extension housing in a 4X2 ) or bad speed sensor. Problem could also be in the exciter wheel in the trnafer case.
