Old 11-03-2009, 07:50 PM   eBay Motors   #1 (permalink)
custamaxlb7
custamaxlb7's Avatar
changing to synthetic
Ok guys I have been trying to get as much info as I can, and still being told from unbiased sources that in my case truck having 100 thousand miles that I shouldn't change my transmission oil to synthetic because there's a good chance it will just lead to having leaks..... In your guys experience, is this true? I have to do a tranny flush with in the next two weeks and wanna do it right! Any help would be greatly appreciated!
custamaxlb7 is offline   Reply With Quote
Old 11-03-2009, 07:56 PM   eBay Motors   #2 (permalink)
chad
chad's Avatar
if you have regualry serviced your truck, you wont have any problems. thats an old myth in my opinion. what kind of synthetics are you going to use?
Night Stalker
2004 chevy 2500hd crewcab sliverado
Amsoil equipped, hmmmm, i cant remember the rest
81 camaro "its just a 350"
chad is online now   Reply With Quote
Old 11-03-2009, 07:58 PM   eBay Motors   #3 (permalink)
custamaxlb7
I'm thinking the amsoil torque drive for the transmission but am open to suggestions.
Old 11-03-2009, 07:59 PM   eBay Motors   #4 (permalink)
WisconsinHick1
WisconsinHick1's Avatar
I run Amsoil TD in my transmission and transfer case and haven't had a problem yet nothing but the best for my truck.
A FEW MINOR UPGRADES
Tuned by MMLMM
SC V
Old 11-03-2009, 08:11 PM   eBay Motors   #5 (permalink)
Chevy*tough
Amsoil T-1 Certified
Chevy*tough's Avatar
yup i would call that a myth!!...As for the Amsoil TD it would be well worth putting in your tranny no matter what the mileage. my truck has over 144,000 and when i get the some cash i will be switching out the tranny fluid as i think it is time to do!
If i can be of any assistance let me know
My 01 duramax LB7 AMSOIL Equipped, 143,xxx miles, 4in stainless w/5in tip, EFI LIVE AND ISSPRO GAUGES
265 nittos on Helo maxx8 black. 3rd limp
Your performance PALACE>>HUSKER DIESEL
Donovan Turek
AMSOIL DEALER
ZO#1709749___#715-563-7136
chevy*tough for all your Amsoil needs!
ALL IN ONE Logistics LLC.
Chevy*tough is offline   Reply With Quote
Old 11-03-2009, 08:13 PM   eBay Motors   #6 (permalink)
K9Duramax
K9Duramax's Avatar
Amsoil would be a good choice.... No, that is an old wive's tale- at least with this newer equipt. and seals. Get a hold of BDD, Mr. Manners, or Chevy tough.... they will hook you up!!
'05 CC/SB, AMSOIL 5w-40, KN Cold Air Intake, PPE Tuner level 1, EGR blocked, MP mod, res. plugged, lost KITTY, finished off the rest with 4" SS Magnaflow
Synthetic Motorsports
http://lb7.info/
K9Duramax is offline   Reply With Quote
Old 11-03-2009, 09:22 PM   eBay Motors   #7 (permalink)
custamaxlb7
another question, I have been reading about doing tranny flushes. Should I be doing it if allison says dont do it? The fluids getting pretty broken down telling from the color on the dipstick. Thanks again
Old 11-03-2009, 09:26 PM   eBay Motors   #8 (permalink)
WisconsinHick1
When your drain all the old stuff out the Amsoil will push the old stuff out when you change your spin on filter and all. You'll be fine with just draining the pan no need too worry about the other fluid.
Tuned by MMLMM
SC V
Old 11-03-2009, 09:28 PM   eBay Motors   #9 (permalink)
buckmeister2
you need to find some new unbiased opinions. that is an mythical legend from the very first days of synthetic motor oil use, about 25 years ago, when it could cause leaks in motors that had used low-detergent or non-detergent oils all their lives. there is no relativity.
i had 172,000 on my tranny when I switched to amsoil TD, and have had no leaks,and no problems.
buckmeister2, carson city, nv, 2004 dmax lb7 4x4,ext. cab LT SB, loaded, 3.73 rear, 168,000 miles, Banks 4" turbo-back pipe, no cat, HUGE muff + AirRaid CAI (both PO install), Mild ECM program by IdahoRob , Rollover ball gooseneck hitch for towing '09 Cougar 5th wheel, 35', 10,600 pounds
buckmeister2 is offline   Reply With Quote
Old 11-04-2009, 08:14 AM   eBay Motors   #10 (permalink)
bigdaddydiesel
bigdaddydiesel's Avatar
Last year when I bought my dually it had 116K on the clock and I did a full flush with Torque Drive and have had zero issues. In fact I am very satisfied with my results! I agree with the above, that is a Myth about not flushing at that mileage.
Chris Kelley
Dealer Referral ID # 1678239
Email
1-888-563-5143
Winter Blend Fuel Additives
