04 LB7 IGN 0 Fuse keeps blowing! - Chevy and GMC Duramax Diesel Forum
 1Likes
post #1 of 11 (permalink) Old 09-09-2010, 10:31 PM Thread Starter
Basshole1's Avatar
Ladies and Gents!
I thought I had this problem solved as the truck has been running great for the past two weeks!
I replaced the NSBU switch, along with the ign 0 fuse found on the drivers side dash fuse box. I also removed the two ground wires found underneath the drivers door, sanded the undercoating off, put the wires back on and painted.
The truck has run with no problems for about 700 miles.
Tonight I replaced the Ignition switch.
Yesterday the same problems developed that happened two weeks ago.
Limp mode - 3rd Gear only, harsh clunk in reverse and drive.
No indicator for PNRD3
Speedometer and trans temp at zero
ABS and service brake on DIC
and IGN 0 fuse blows.
No codes are displayed
Tach, oil pressure, water temp, voltage all work.
The IGN 0 fuse blows even with the connectors disconnected from the NSBU as soon as I turn the key to the "on" position.
My theory is that there is a short in the wiring harness with the pink wires going from the IGN 0 fuse to the transmission NSBU switch.
However I also notice in the schematics, the pink wires also connect to the VCM and the PCM.
Any help is appreacited.
Thanks
Basshole1 is offline
post #2 of 11 (permalink) Old 05-27-2011, 10:32 PM
dmax1983's Avatar
I'm having the same problem as you. Did you ever get that taken care of? I did replace the NSBU switch and that didn't fix the problem.
The truck stopped clunking into reverse or drive. The shift indicator is gone, the speedo and trans temp works, the service brake system went away,
the truck seems locked into 3rd gear, but I can go up to 70mph like normal. I replace the IGN 0 fuse, turn the key and it blows with a spark.
I inspected for any cut wires and couldn't find any. Should I buy a new IGN Switch?
I would like to get this figured out without taking it to any stealerships.
Will driving the truck with the IGN 0 fuse out hurt the truck?
Any help would be great!
dmax1983 is offline
post #3 of 11 (permalink) Old 05-28-2011, 01:22 AM
AdamAnt's Avatar
I have had a similar problem in the past, just my IGN 0 fuse was not blowing, IGN 0 fuse is TCM (IIRC)...check DDM fuse or drivers master switch, mine was gummed up/dirty best I could tell. So I took door panel off, took switch apart, cleaned, all was good.
I assume you have power windows? So...
You could pull the DDM fuse and see if it all works correctly.. You might have to turn key on/off a couple of times, to cycle whatever setting, I have had to wait a couple minutes in between. You could try leaving the DDM fuse out but you will not have use of drivers power window functions. You can replace once vehicle is on to restore use of master window switch, if fuses blow or symtoms happen you know source, if not... whats 2 seconds to pull a fuse.
If you find DDM is bad, and are to buy a new DDM it has to be programmed by dealership, so I would suggest to try cleaning connections or pulling fuse to get it to work.
I hope this makes sense it worked for me took me couple days of testing all connections with multimeter and researching before I found only other guy that suggested DDM was culprit.
DDM is connected to transmission it auto-locks the doors when you begin driving, if it is shorted it could cause transmission troubles.
DDM is drivers door module ... basically drivers master power window switch. who would have thought....
I have a 2005 LLY... and yours maybe different, thought I might give it a shot and point you in a direction, or maybe I typed all this for nothing...LOL
shadow02 likes this.
2005 Silverado 2500HD
Diamond Eye DP back 4" exhaust, LBZ Mouth Piece, EGR delete, cognito pitman/idler supports, AMSOIL Fluids
trying to improve fuel economy.... but loving every minute of it
:rockin
AdamAnt is offline
post #4 of 11 (permalink) Old 05-28-2011, 08:41 AM Thread Starter
Basshole1's Avatar
dmax1983 - Yes, problem was solved. There is a wiring harness inside the transmission pan. One of the wires had rubbed the insulation off and was shorting inside the pan. Replaced the harness and problem went away.
post #5 of 11 (permalink) Old 05-28-2011, 07:01 PM
dmax1983's Avatar
I pulled the door panel, pulled all the DDM connectors and they were all clean, dry with straight pins. Then I put another IGN 0 fuse in with the DDM deleted, turned the key on and the fuse blew.
After that I pulled the DDM fuse with DDM and door panel back in place, turned the key on and the windows didn't work. Put another IGN 0 fuse in, turned the key, didn't blow. But I cranked it and the fuse blew.
Put the DDM fuse back in now the windows work. I think my DDM is good.
2004 LLY 2500HD GMC Sierra 6.6 Duramax
S&B CAI, MBRP Down-pipe, BD Exhaust Manifold,
MBRP 4 inch Exhaust, Sinister EGR Delete Kit,
PPE Standard, AFE Turbo Mouth Piece,
AFE Intercooler Tube Combo, Cobalt Boost Pyro
http://www.youtube.com/user/DieselPowerTV
dmax1983 is offline
post #6 of 11 (permalink) Old 05-28-2011, 07:08 PM
dmax1983's Avatar
I pulled my trans pan, inspected the wiring harness and didn't see any wires rubbing. Nothing look out of the ordinary.
dmax1983 is offline
post #7 of 11 (permalink) Old 05-28-2011, 07:18 PM
You cannot tell by looking at wires if they are bad or good. Youu need an amp meter and check load. Ohms don't tell you much and neither does voltage. You can have 12V and it will pass voltage on a single strand of wire but will not trigger a solenoid because of low amps.
Mike L. is offline
post #8 of 11 (permalink) Old 02-13-2015, 04:01 PM
Well I have a similar problem but mine is a little different 04 2500 hd duramax lly and my truck starts fine runs ok rpm and speedo gauges work all my dash lights work except my trans temp oil pressure and fuel gauge and volt meter don't work. My stereo and 4x light panel doesn't work neither do my power locks or power windows. Took it for a burn up to 120km/h runs good shifts fine a little late on the shifts but just seems like a wiring issue. Had the instrument cluster rebuild still didn't fix it. Engine light comes on sometimes and say service 4WD. Any ideas???
ChevyStr0ng is offline
post #9 of 11 (permalink) Old 07-19-2016, 07:02 AM
Same
Did you ever solve. I am facing exact same problem and not sure what next step should be? I would love to hear what you ended up doing?
jrannis73 is offline
post #10 of 11 (permalink) Old 07-27-2016, 04:14 PM
Having a similar prob on 2002 silverado crew cab and have the dash down to the firewall. Never crossed my mind that it might be inside the trans. I have noticed it to be heat related and once it starts blowing fuses you will have to wait overnight then it is usually ok the next day. I also have the cargo light is on warning and cant get that off.also the right high beam is not getting it ground so i may have several problems, just wish i could fix one. oh well makes me not mind changing out the pms on my97 about once a year.lol
hamerhead is offline
