Stuck in 3rd gear - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 10-13-2010, 03:28 PM Thread Starter
Stuck in 3rd gear
My allison transmission every now and than gets stuck in a gear usually 3rd. I have to take my superchip off to stock and back to performance than back to stock and clear the dtcs and after a mess of times it finnaly gets the code off. The dtc is reading a cylinoid problem has anybody had a problem with this and is it easy to fix. HELP ME!!!!!
kountryboy1221 is offline
post #2 of 8 (permalink) Old 10-13-2010, 04:19 PM
tigermack's Avatar
Send a message via AIM to tigermack
You're limping the tranny, lower the tune and be more gentle on it. Once the trans limped, it starts getting limped easier.
03' EC LB7 2WD
T6 Rotella - Napa oil filter
Amsoil Torque-drive - Napa filter
PPE standard & boost valve | Bilstein 5100's | Prosport EGT & boost gauge w/ Autometer dual overhead pod | Pioneer Avic D3
tigermack is offline
post #3 of 8 (permalink) Old 10-13-2010, 04:33 PM
DIESEL MANIAC!!!
KSL667's Avatar
i've never heard of the trans limping from power and sticking in third. i had this happen to my old dmax once after i went through a cable fence. some safe mode. i'd try updating the superchips
-Kyle
2011 GMC 2500hd LML deleted and tuned by Kory, 5' exhaust with XD rims, Level Kit and HID HIGH/LOW beams
Sold - 2008 Chevy K3500HD CC/LB LTZ with LMM Dmax
Sold - 2004 Chevy K2500HD Ext. Cab/LB w/ LLY Dmax
KSL667 is offline
post #4 of 8 (permalink) Old 10-13-2010, 04:49 PM Thread Starter
Can it have to do with a bad cylnoid I had this problem right when I got the chip and it did it once transmission guy said he thought the cylnoid was malfunctioning. it does it when I start the truck up and it will go to third gear and stay there its not when im driving does that change anything?
post #5 of 8 (permalink) Old 10-13-2010, 05:11 PM
Administrator
jc1843's Avatar
You need to fill out your signature with the year and any mods-- that helps when you ask a question. Click User CP top left.
You need to post the code- otherwise we will have to "Guess" ! There are many Techs on this site and they will gladly help.
jc1843 is online now
post #6 of 8 (permalink) Old 10-13-2010, 05:14 PM
Duramax Forum Moderator
DuramaxOnTheBrain's Avatar
Uh yeah the tranny will limp from power and stick in third..... I did it when I had my PPE on level 5...... it's the clutches slipping that makes it limp. All you can do is stay out of it and save up for a rebuild...... sux.
Brian
PPE Standard level 2
Kodiak mouthpiece
Truxedo Duece Tonneau
06 style leveled towing mirrors, 285 75 R16 BFG AT KO
BUY FROM MPF!!!!!
DuramaxOnTheBrain is offline
post #7 of 8 (permalink) Old 10-13-2010, 05:15 PM Thread Starter
PO975 and p0700 are the codes that are displayed does that help at all?
post #8 of 8 (permalink) Old 10-13-2010, 05:51 PM
rippinmax's Avatar
I had the same problem with my 05 only anti freeze blew out of the over flow and now it won't stop dripping out of the over flow. Anyone know how to fix it?
rippinmax is offline
