Hey Guys My Truck Just Rolled 75k, And I Dont Think The Tranny Fluid Has Ever Been Drained, I Smelled It Today And It Smells A Little Used Crispy, Should I Just Change The Screw On Filter, And Pull The Plug In The Pan,and Then Just Refill It. Or Do I Have To Take The Pan Off And Change The Inner Filter.
__________________ 2004 CHEVY LB7 2500HD, CREW CAB, SB. EDGE JUICE WITH ATTITUDE, AFE STG. 2, PPE BOOST VALVE, FASS 95, 4 INCH SILVERLINE, PPE SLEEVES, TOYO MT`S
About How Much Fluid Will I Need Ta Go Get Before I Pull The Plug.
Since I Wont Be Drainin The Converter, Should I Just Use The Dextron
It's not available in my area either, I have to order it. If you live close to a allison dealer you could go with tranysnd synthetic. That is the allison brand synthetic which is also very good.
__________________ KYLE
