truck shifts hard - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 12-02-2010, 08:28 PM Thread Starter
truck shifts hard
Im looking at buying a 2003 Duramax with 174k
He says it has a diablo chip and a shift kit on it.
also has a straight exhaust.
But when i test drove it and got on the gas to the floor when it shifted gears it shifted kind of hard? is this normal for diesel trucks or cause it has the shift kit? or is it the transmission is bad?
ive talked to a few buddies that have duramax's and some say theres does it a little bit but there thinking the shift kit is what causes it.
kane_munn is offline
post #2 of 14 (permalink) Old 12-03-2010, 02:46 PM
red1977's Avatar
if it has a shift kit it will shift harder
2001 EC/SB
S466 billet.
Tuning is on crack.
Trans from EPR
4 inch exhaust.
Raptor
Traction Bars.
510hp 1244 tq uncorrected. Stock Turbo, injectors,cp3.
13.02, Stock turbo, injectors, cp3.
2014 Chevy 2500hd CC/SB. all stock.
red1977 is offline
post #3 of 14 (permalink) Old 12-03-2010, 03:24 PM
devo's Avatar
Send a message via AIM to devo
mine has a shiftkit and doesn't shift hard?..maybe he romped on it hard alot so the allison learned that type of shift pattern from the driver,and you went to test drive it and it wasn't used to ur driving and got confused..they can do that since there learning trannys.it adjusts to every shift or so...if you end up buying it,do a tranny re-learn with the programmer,assuming it has that option and go through the gears 1/4 throttle 1/2,so on so forth a few times,check fluid levels,ect...
My truck
05 LLY CC/SB Slt
caltracs,efilive,lowered on chrome 20x12's and a stock tranny!
devo is offline
post #4 of 14 (permalink) Old 12-03-2010, 04:04 PM
saw what you did there
theunderlord's Avatar
Stop. you've said enough.. walk away.....
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #5 of 14 (permalink) Old 12-03-2010, 08:19 PM
It better not. Hard shifts in an Allison are tie ups. That is being in two gears at the samd time. Allisons must not shift hard.
Mike L. is offline
post #6 of 14 (permalink) Old 12-03-2010, 08:33 PM
Ktm238's Avatar
You cant even put a shift kit in a 2003 because it doesent have the 6 speed its full tranny rebuild or nothing, correct me if im wrong but i think thats the case???
2006 LBZ, Freedom Diesel / Suncoast Trans, EFI Live by Tony at Ridgerunner diesel, 4" in MBRP turbo back exhaust, MBRP Downpipe, 5" tip, EGR delete, Transgo Jr, PCV re-route, PPE Air Box Mod, Cognito UCA'S , PPE Tie Rod Sleeves, Bilstein 5100's, Tow mirrors, Nitto Terra Grapplers 285/75/16, Air dog 165
Ktm238 is offline
post #7 of 14 (permalink) Old 12-04-2010, 09:48 AM Thread Starter
and how would i reprogram it when it doesnt have a programer?
it just has the diablo predator chip.
yea but when i was driving normal it didnt do the shifting like that, it just did it when i romped on it it was like a lag kinda and it threw the truck
post #8 of 14 (permalink) Old 12-04-2010, 09:49 AM Thread Starter
what you mean?
post #9 of 14 (permalink) Old 12-04-2010, 02:13 PM
Administrator
jc1843's Avatar
The 6 speed TransGo Jr shift kit, will fit in the 5 speed, but does not do much. If installed it correctly, it won't hurt it either. Only way to help a 5 speed is internal modifications!
jc1843 is offline
post #10 of 14 (permalink) Old 12-04-2010, 02:26 PM Thread Starter
Its an automatic transmission
