Old 07-11-2008, 07:51 PM   eBay Motors   #1 (permalink)
Andrew57
Points: 699, Level: 9
Points: 699, Level: 9 Points: 699, Level: 9 Points: 699, Level: 9
Activity: 0%
Andrew57's Avatar
PPE Level 4 Tranny?
i justed tuned my lmm with the ppe stadard and i also enabled the tranny relearn and when i gas it, it feels like the transmission is slipping and not catching the next gear??? any way to fix this problem or prevent this??? will this mess up my tranny???
Andrew57 is offline   Reply With Quote
Old 07-11-2008, 08:48 PM   eBay Motors   #2 (permalink)
blackdeath
Points: 4,554, Level: 28
Points: 4,554, Level: 28 Points: 4,554, Level: 28 Points: 4,554, Level: 28
Activity: 46%
Activity: 46% Activity: 46% Activity: 46%
blackdeath's Avatar
humm sounds weird , try reloading it and doing a relearn again, if that dont work i would really reduce the power.
2008 silverado dmax LTZ, aFe stage 2 ppe level 5, dpf delete, EGR block off plate , autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, fabtech tierods, 35"nitto a/t. 5" grandrock stack kit,straight piped
2008 traiblazer ss, straight pipe , 1.5" down
blackdeath is offline   Reply With Quote
Old 07-11-2008, 08:55 PM   eBay Motors   #3 (permalink)
ironcrossmike
Points: 2,227, Level: 19
Points: 2,227, Level: 19 Points: 2,227, Level: 19 Points: 2,227, Level: 19
Activity: 0%
You might give it a day or two to learn what's going on with the extra power
"When in doubt,STAND on it!!!"
2007.5 Crew cab dually with LMM and 6 speed, B&W hitch,4"Diamond Eye exhaust,PPE Xcellerator Hot+2 Race, Autometer Sport Comp2 boost and pyro gauges.Transgo Jr. Custom bent tailgate thanks to a lowriding GN trailer!
ironcrossmike is offline   Reply With Quote
Old 07-11-2008, 09:23 PM   eBay Motors   #4 (permalink)
BigRedChevy
Post Slut
Points: 10,854, Level: 45
Points: 10,854, Level: 45 Points: 10,854, Level: 45 Points: 10,854, Level: 45
Activity: 100%
BigRedChevy's Avatar
That is the tranny learning. Do some city driving where it can shift threw all of the gears easy before getting on it harder. Start out taking off easy and when it shifts good like that step it up a little.
KYLE
Old 07-11-2008, 10:20 PM   eBay Motors   #5 (permalink)
r.laz
Points: 3,004, Level: 22
Points: 3,004, Level: 22 Points: 3,004, Level: 22 Points: 3,004, Level: 22
Activity: 0%
r.laz's Avatar
Some say that level 4 and up might be too much for a stock tranny (most likely true), but I also am running on this level for sometime now w/ no tranny mods. So far so good, but I try to avoid boosted launch. Give your tranny sometime to relearn and put it on fast learn mode. When I'm relearning my tranny I drive aggresively and try to run it at different types of roads.
08 Sierra WT CC SB
Steel Gray 4x4
PPE RACE
Modded OEM AirBox/PCV Reroute/4" MBRP into 5" MagnaFlow/ EGR BLOCKED
Isspro EGT/Boost gauges Cognito Leveling Kit/HD Tie Rods Pitman/Idler Support Brackets/Bilsteins
Pirelli Scorpion ATR 265/75/16 Coated OEM Wheels
Factory Oval Steps/Rhino Lining
Klein Air Horns (4)/ViaAir 150 psi 2g compressor
r.laz is offline   Reply With Quote
Old 07-12-2008, 07:42 AM   eBay Motors   #6 (permalink)
TYREBOYZ_DEMAXIN
Experienced Post Whore
Points: 10,982, Level: 45
Points: 10,982, Level: 45 Points: 10,982, Level: 45 Points: 10,982, Level: 45
Activity: 100%
TYREBOYZ_DEMAXIN's Avatar
also your truck has a defueling feature so that could be part of what your feeling.
James
I HAVE THE MEDAL
Old 07-12-2008, 08:13 AM   eBay Motors   #7 (permalink)
Andrew57
Activity: 0%
Andrew57's Avatar
what is the defueling feature for?? should i enable that option??
Old 07-12-2008, 08:17 AM   eBay Motors   #8 (permalink)
TYREBOYZ_DEMAXIN
Activity: 100%
yes it there to protect your tranny,what it does is it cuts engine power so an unmodified tranny can shift without destroying it and then after the shift the power returns,the longer you drive it the less noticable it will be.
James
I HAVE THE MEDAL
Old 07-12-2008, 09:25 PM   eBay Motors   #9 (permalink)
Andrew57
Activity: 0%
Andrew57's Avatar
for any people with the same truck n programmer with successful results! what settings and what features should i enable? i also was wondering i have a dpf back 5" mbpr and the programmer set on level 4 and my mpg has not went up at all any suggestions?? should i look into getting an colds air intake with all the power??
Old 07-12-2008, 09:28 PM   eBay Motors   #10 (permalink)
BigRedChevy
Post Slut
Activity: 100%
That is to force a regen cycle. If you feel you DPF is clogging you can force a regen istead of waiting on the truck to do it.
KYLE
