Transfer case fluid? - Page 2 - Chevy and GMC Duramax Diesel Forum
post #11 of 40 (permalink) Old 12-10-2010, 12:09 PM
catmenace's Avatar
I would like to know benefits vs disadvantages on what to use. I used Transyn before but switched to 5W synthetic after I read that ATF may not be as good to use.
2011 GMC 3500 DRW CCLB
2012 BMW X35I
2012 GTR - 0 to 60 in 2.9 Sec
catmenace is offline
post #12 of 40 (permalink) Old 12-10-2010, 12:29 PM
ATF is known to vaporize in these hot transfer cases. We have seen many, many trucks come in here with little to no fluid in them with no sign of a leak. It seems that not many people are checking their levels when they service their trucks. Using the synthetic motor oil will have less tendancy to vaporize and will lubricate better. It is somewhat of a safeguard for people that don't check the TC fluid levels.
If you check your TC fluid on a regualar basis you won't need it.
Believing everything GM tells you is stupid. They are the ones that put Dex 6 out there without testing it. Two years later they find out it is not compatible with the 5 speed seals and it solidifies at -40F plugging the cooler lines with frozen fluid and cooking the Alli so bad they can no longer be rebuilt.
Be carefull which KoolAid you drink. I've heard it tastes salty.
Mike L. is offline
post #13 of 40 (permalink) Old 12-10-2010, 12:49 PM
Bustedknuckles's Avatar
I put merc3 in mine, that's what alldata told me to use???
Kervin. 04 lb7 with 06 front clip. Built trans, head studs, S366 from EPR, 30% injectors, Idaho Rob tunes, 20X10 BMF Novakanes etc....
Bustedknuckles is offline
post #14 of 40 (permalink) Old 12-10-2010, 12:53 PM
jayfa82's Avatar
what grade of 5w are we talking about? 5w what?
2002 Chevy 2500HD LT CCSB 4x4 LB7, Charcoal Gray
Goodies:
S&B intake, Edge Juice w/Attitude, PPE boost valve, DDP 75hp injectors,
modded intake horn, BD manifold, 5" MBRP TB exhaust w/ 8" tip
turn-over ball, sprayed-in bedliner, Westin step bars, smoked red tail lights
Maybe Someday:: AirDog II 150, PPE Stage V w/Precision ML, EFI Live
Special thanks to Chris at All In One Logistics, Tyler at Meyer Performance and Fabrication, Nate at Performance Truck Products, and Jess at Husker Diesel
jayfa82 is offline
post #15 of 40 (permalink) Old 12-10-2010, 12:55 PM
blackdeath's Avatar
ok u have one little seal seperating the trani and tcase , and i love that people will argue the fact that theres no way tcase can leak in the trani .but u know what, u do this for a living long enough ull learn really fast that the word never is NEVER acurate in this industry , and 1% thats already happened is a chance way to high to take on this trani , check the fn tcase fluid when u change ur oil ull never have any issues
blackdeath is offline
post #16 of 40 (permalink) Old 12-10-2010, 12:59 PM
Oxcart's Avatar
Originally Posted by Mike L. View Post
Actualy it's not.
Originally Posted by bnkrupt View Post
to each their own. Run vegetable Oil for all I care.
What do I know anyway?
Really, You are arguing "what do I know" against Mike when it comes to this stuff? Come on I know you're smarter than that....
He has been doing this a lot longer than you and I put together....
I run 3 quarts of Synthitc Motor oil 5w-30 in my T-case. You will have to fill through the speed sensor hole to do this though.
Mike
2008 LMM
2002 LB7
Running MMLMM "Grim Reaper" tunes
Oxcart is offline
post #17 of 40 (permalink) Old 12-10-2010, 03:28 PM
GeorgiaDieselGTO's Avatar
I run motor oil
Daily driver:06 LBZ Custom cut pistons and head studs, lift pump EFILive and built trans by me by me and a few other goodies 521/1065 on stock turbo and injectors sold :cry
Barn hauler:08 LMM 3500 regular cab Exhaust, EFILive by me. head studs, (bought it with blown head gaskets) and a little other custom work
GeorgiaDieselGTO is offline
post #18 of 40 (permalink) Old 12-10-2010, 03:31 PM
Oxcart's Avatar
I have a very smart buddy when it comes to theses things, and he never once checked t-case fluid, cared to check it, or cared what fluid to use and he never had one single issue in the 6 years of owning that truck, and he abused it pretty good.
It was a 2wd though : )
Mike
2008 LMM
2002 LB7
Oxcart is offline
post #19 of 40 (permalink) Old 12-11-2010, 07:45 AM
blackdeath's Avatar
thats funny cause ive had 2 seal failure in less then a year, id lie to do it but i cant risk it , oh well
post #20 of 40 (permalink) Old 12-11-2010, 07:50 AM
blaineGMC's Avatar
lol i see what your trying to hide.
Blaine
04 LLY Suncoast/Precision ML by me. Tuned by Rob.
AFE, MBRP, Mag-Hytec, Merchant Automotive, SSBC, Bilstein
For EFI Live go to:
blaineGMC is offline
