p0841,and p0846 codes - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 12-30-2010, 04:40 PM Thread Starter
hi, was wandering if someone could help me with theys codes..I have a p0841 that says trans psi switch solenoid c stuck off,p0846 trans psi switch solenoid d circuit stuck open.I tried to put the truck in grear when fluid was not all the way full..The truck seems doggy,if i take off from a dead stop and put it to the floor it is real doggy untell it hits what i think is 2nd gear..the truck is a 2001 gmc 2500.. Thanks for any help
skw20 is offline
post #2 of 3 (permalink) Old 12-30-2010, 05:45 PM
You lost pump prime. You are either low on fluid or you have a converter drainback problem.
Mike L. is offline
post #3 of 3 (permalink) Old 12-30-2010, 06:22 PM Thread Starter
thanks, i will double check my fluid..thanks again
skw20 is offline
