In my '04 2500HD My ABS light comes on intermittently, Code Reader tells me C0055 is rear ABS sensor. So I replaced the Rear Speed/ABS sensor in the Transfer Case but no luck still getting intermittent ABS light.
Read this can be a wiring problem so unplugged and re-plugged ABS harness connectors I could find and cleaned up the ground wires under drivers door near Cab Mount, but still no luck.
This is also affecting my cruise control as it seems to "hunt" around the set seed and won't stay constant.
Anybody solve this when it wasn't the ABS/Speed Sensor?
