Just had GM replace my tranny and I now have alot of slop/play when in reverese up a small incline or the tranny just does not want to hold, when it does catch, I get alot of noise out of it.
My old one never did it, is this something I should live with?
Take it back to GM and have someone ride with you to let them know whats going on. Don't think I would keep driving it like that especially after it was replaced.
__________________ NAME: JIMMY
2001 CC/SB Duramax LT 4x4 LB7, Solid axle conversion, 14" lift, 16.5" Eagle Alloys, 40x18x16.5 Mickey Thompson Baja Belted Tires, PPE Hot+2, PPE Boost Valve, Ported Mouthpiece, Van Aaken performance smart box E (for sale), MBRP 4" Turboback Straight Pipe, Smoked and LED Tail Lights, (4) 10" Subs with Audiobahn amp.
LIFE'S TOO SHORT, PARTY NAKED!!!
I do not think you would have slippage if it was the rear. It would have the same issues in forward and reverse. I would check the fluid level in the trans and see if it is low. Does the truck act like that in drive?? If it does there may be torque converter issues. I would also take it back to the dealer and tell them there is something wrong. Did they give you a warranty on the new tranny??
__________________ 06 2500 CREW CAB 4X4 LBZ LOONNGGGGG BED 4" DIAMOND EYE EXHAUST, EFI LIVE,DSP5,S&B COLD AIR INTAKE, RESONATOR PLUGGED AUTOMETER ULTRALITE GAUGES, TRANSGO JR, EGR BLOCKED!!!!285/75 BFGs ON ULTRA DYMONDS, TIE ROD SLEEVES....
WORK RIG
DPF GONE!!!EFI LIVE,DSP5, K&N FILTER, MAF CLEANER IN BED
This is not only your forum you have to share it with over 30,000 others
what year truck is it?
i find it hard to beleive that it would be the rear end but it is possible,my guess is the tranny is not done right or something to that nature.i would take to another tranny shop and see what they say about it.
__________________ James
Priority List
God
Wife
Her Car
Work Car
then the Truck
I'm no transmission specialist,but the 2nd gear is on the same band as reverse IIRC.If they messed up in the build it will only reflect it in reverse or second gear,if that applies to an Allison trans like some of the older Hydramatics.Not saying it's the smokin gun, but gives you an idea of what I mean.Maybe one of the trans gurus will chime in on adjustment,if there is such on the Allison unit....
__________________ 06.LBZ GMC[SLE1] 4x4 .modded a touch!PPE hot+2!
.STAGE V Suncoast,Merchant 4x4,str8piped,285's,
1978 Malibu[2dr.]350ci crate/TH 350 with goods,3.23's 1987 Monte Carlo SS 92k original milesPM regarding MPG will not be answered!! 2001 GMC ex-cab 5.3,tuned,20'Helios
They did an adjustment once already on it as I had a hard shift frequently going from second to third and I still get the shift like that.
I've only got play in reverse while going up a small incline, forward is fine.
I'll end up taking it back again, but the problem is finding an incline around the dealership to test it out and make it repeat.
The tranny guy did tell me last time he was going to try to get me a new replacement, but that went nowhere.
