Old 08-26-2008, 06:42 PM   eBay Motors   #1 (permalink)
oleblacky
Points: 787, Level: 10
Points: 787, Level: 10 Points: 787, Level: 10 Points: 787, Level: 10
Activity: 7%
Activity: 7% Activity: 7% Activity: 7%
oleblacky's Avatar
tranny reset?
Ok why do you reset the tranny? How do you do it? Do you have to relearn the alli. again? Just kind of curious!!!!!!!
Thanks
2006 Silverado LT Crew Cab
Durmax LLY Allison/6speed
Straight Piped Kitty Ran Off
Resinator Plugged PCV Reroute
285/75/16 M/T wheels
Work Truck 08 LT LMM
Summit White Crew Cab
Bone Stock
oleblacky is offline   Reply With Quote
Old 08-26-2008, 06:48 PM   eBay Motors   #2 (permalink)
Johnasara
Points: 4,205, Level: 27
Points: 4,205, Level: 27 Points: 4,205, Level: 27 Points: 4,205, Level: 27
Activity: 15%
Activity: 15% Activity: 15% Activity: 15%
Johnasara's Avatar
I reset mine with the diablo tuner. Any time you do performance upgrades to the ecm it will go into relearn. When I put in my Transgo JR I had to relearn but I also turnd my diablo up to 120rwhp. I do not know if there is a way to make it relearn with out a programmer. The allison uses your driving habits to learn how to shift for how you drive.
06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 120HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD. TRANSGO JR
WORK RIG
O7.5 3500 CREW, LMM, ROYAL UTILITY BED
4" DIAMOND EYE EXHAUST.DPF???KITTY?? QUADZILLA PROGRAMMER. MTX AMP AND 10" TWINS IN THE BACK. STEPS,VISORS,BUG SHEILD. AIRBOX IMPELLER REMOVED,RESONATOR PLUGGED,LOTS OF PRETTY DIAMOND PLATE EVERYWHERE
Old 08-26-2008, 06:49 PM   eBay Motors   #3 (permalink)
Maverick684
Points: 3,620, Level: 25
Points: 3,620, Level: 25 Points: 3,620, Level: 25 Points: 3,620, Level: 25
Activity: 1%
Maverick684's Avatar
You usually reset the tranny to allow it to adjust to a new power level produced by the engine. It usually takes the alli about 30 to 50 mi. to relearn the new power produced by the engine if it is reset. If you are able to reset the tranny it just allows it adjust faster than if you just re-adjust power levels and drive off. This could potentially be harder on the trans as it tries to adapt to the new power. It will basically change the line pressure and shift points and firmness to accomodate the new power. If you can reset it I would do it, otherwise just drive easy on it for the first 75-100mi. and it will adapt, also make sure the driving you do is varied i.e. lots of stop and go etc.
05' Dmax LLY CC SB, 6in. Fabtech with Heavy duty tie rods,
6000K HID headlights & fogs,
Upcoming mods: Lift pumps, Fully built tranny
On the Way: PPE intake manifold w/EGR delete
Maverick684 is offline   Reply With Quote
Old 08-26-2008, 06:54 PM   eBay Motors   #4 (permalink)
oleblacky
Activity: 7%
oleblacky's Avatar
Ok thanks for the info. But no way to reset t without a tuner?????
Bone Stock
Old 08-26-2008, 08:49 PM   eBay Motors   #5 (permalink)
BigRedChevy
Post Slut
Points: 10,854, Level: 45
Points: 10,854, Level: 45 Points: 10,854, Level: 45 Points: 10,854, Level: 45
Activity: 100%
BigRedChevy's Avatar
What are you wanting to reset it for? If you don't have a tuner your tranny shouldn't need to be reset.
KYLE
Old 08-27-2008, 03:54 PM   eBay Motors   #6 (permalink)
oleblacky
Activity: 7%
oleblacky's Avatar
I was reading about torque convertors getting locked up or something to that nature. They said to reset the tranny and that will fix the prob.(maybe)
Bone Stock
Old 08-27-2008, 09:46 PM   eBay Motors   #7 (permalink)
daddysLBZ
Highway travler!!
Points: 6,295, Level: 33
Points: 6,295, Level: 33 Points: 6,295, Level: 33 Points: 6,295, Level: 33
Activity: 47%
Activity: 47% Activity: 47% Activity: 47%
daddysLBZ's Avatar
When you put in T/haul,then it's locked up after 2nd gear.When you slow to a stop,the trans will feel as if it's dragging,until it shifts down outta second,then you'll almost feel the TC let the pressure off,try it out.The TC being locked ensures that trans does have excessive slippage,so I always use mine when I have it tuned up,loaded or not,I use the Tow/Haul....
MINE2006 GMC 2500HD4x4 sb cc LBZ!Got a couple lil mods,more to follow
[color="Blue"]02 GMC 1/2 ton,2wd,5.3 power{Mama's ride}
87 SS Monte Carlo 77k[orig!]
78 Malibe [2dr.]350/350
WORK RIG:03 YukonXLHypertech tuned!!310k miles!
The left lane is used to pass,so get over,or we'll run over ya asssss!!1996 Impala SS on the way!!!
