Old 08-27-2008, 05:18 PM   eBay Motors   #1 (permalink)
Paccool
Points: 642, Level: 9
Points: 642, Level: 9 Points: 642, Level: 9 Points: 642, Level: 9
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
Tranny coolers
Quick question on the tranny coolers these trucks use. Is there a fan assisted cooler on the truck or just a flat cooler up front? If no fan assisted cooler, has anyone installed an after market one under the bed? (or up front somewhere if there is room) Summit has a decent looking one for a couple hundred dollars.
Tried a search but didn't find anything.
Dodge had an option for an under the bed fan assisted cooler on the old first gens and I was wondering if there has ever been anything like this for the Chevy? They worked pretty good on the Dodges cause my 93 has one.
I like to see temps for my old truck in the 150-160 range to allow for some heating up when towing. Can that be achieved with another cooler installed up front on the 05 I just bought?
Thanks in advance!
Stan
2005 Chevy Silverado 4x4, 285-70-17's on Hummer wheels. 18,000 miles. modified air box W/Amsoil filter. Predator programmer, KillerBee modified mouth piece.
93 Dodge D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust,modified tranny,EGT/boost/tranny/tach gauges.Rear sway bar.Single stage Water/Meth system installed. Oversized intercooler
Paccool is offline   Reply With Quote
Old 08-27-2008, 06:06 PM   eBay Motors   #2 (permalink)
BigRedChevy
Post Slut
Points: 10,854, Level: 45
Points: 10,854, Level: 45 Points: 10,854, Level: 45 Points: 10,854, Level: 45
Activity: 100%
BigRedChevy's Avatar
Just the one in front is all that's on these trucks. The best cooler available for the allison is one that is made by Mike L at inglewood transmission. It is a direct replacement and does better than any of the other after market coolers. Also since you have a 05 look in to modding you turbo mouthpiece and you will see some cooler tranny temps. Do a search on this site for LLY modded turbo mouthpiece and you will get plenty of reading.
KYLE
Old 08-28-2008, 10:57 AM   eBay Motors   #3 (permalink)
Paccool
Activity: 2%
Thanks Kyle
Sorry I posted in the wrong forum, think I would know better! LOL
Yes, I've already seen the discussion about cleaning up the inlet tube as well as removing the foil from the inner fender well to allow colder air to the filter. Saw that last night when putting in a new filter.
Looks like there are a few other things that might help, I'll be looking at them to see what I'm going to try.
Stan
Old 09-03-2008, 11:52 AM   eBay Motors   #4 (permalink)
Killerbee
Points: 3,065, Level: 23
Points: 3,065, Level: 23 Points: 3,065, Level: 23 Points: 3,065, Level: 23
Activity: 18%
Activity: 18% Activity: 18% Activity: 18%
Killerbee's Avatar
Stan
Tranny temps are largely affected by other shortcomings in the LLY platform. Your truck has issues much more serious than tranny temps over 170F, though I understand being particular. For example, if you saw what engine oil temp is...
These issues get resolved in domino fashion when you fix the instigator of them, the king defect, which trickles down to all other performance paramaeters. When you do this, you get rid of some undesireable behaviors, like the fan, IAT degradation, power loss, etc.
Not trying to disuade you from buying a $500 TOC that tends to one symptom, but for half that you can improve several things at once. Remember that tranny temp regulation is by-and-large controlled in the radiator. Consider, if the CAC is blistering hot, and sits in front of the radiator, what chance does the trans have?
WANTED, ALLISON TRANNY CORE CHEAP
Michael, 2500HD LLY
Vehicle Systems Engineer-useful links
THERMAL FEEDBACK INTRODUCTION
PERFORMANCE AND COOLING
WWW.MaxxTORQUE.com No Fluff
OVERHEATING?
T.F. LOOPS IN BLOWN APPLICATIONS
EFILive TUTORIAL Home of the First Ever VGT "wastegate" tune
Old 09-20-2008, 03:51 PM   eBay Motors   #5 (permalink)
deereboy80
Points: 355, Level: 6
Points: 355, Level: 6 Points: 355, Level: 6 Points: 355, Level: 6
Activity: 0%
deereboy80's Avatar
There is also a cooler built into the rad on the 5 speeds. This will make the oil run about the same temp as the engine. Seems a bit warm to me, but my shop says its about normal to tow at 215 deg. Truck isn't slipping much yet, just a bit rough from 4 to 5.
'04 GMC LB7 Crewcab Shortbed
AFE Stage 2 Intake
Diamond Eye 4" Single Exhaust
Edge Juice w/Attitude
Air Lift 5,000Lb bags with Ride Control
B&W Turnover Ball
RollBAK roll tarp
deereboy80 is offline   Reply With Quote
Old 09-20-2008, 05:30 PM   eBay Motors   #6 (permalink)
samdweezel05
Points: 2,021, Level: 18
Points: 2,021, Level: 18 Points: 2,021, Level: 18 Points: 2,021, Level: 18
Activity: 2%
samdweezel05's Avatar
215 degrees?????? I would say you have a problem. even when my allison was stock I never saw over 170 degrees when towing, no matter what I was pulling. Now that it is modified I see 150-160 degrees when towing or not.
Phil
2003 Chevy 2500 HD reg cab long box.
EFI Live, HTT Promax 66 5571 Turbo w/stainless Exhaust Housing, Air Dog 150 Lift Pump, PPE Boost Valve, AEM Brute Intake, Coolingmist Water/Methanol Injection, MBRP 4" Stainless Dual Exhaust, Suncoast Stage IV w/ 1056, MB Gunner 8 rims with 265/75-16 Nitto Grappler AT's, Stainless Tube Steps, Aluminum tool box, 5% tint all the way around, Manly pintle hook with 2 5/16" ball
There's a balistic solution for everything.
samdweezel05 is online now   Reply With Quote
Old 09-20-2008, 07:38 PM   eBay Motors   #7 (permalink)
deereboy80
Activity: 0%
deereboy80's Avatar
Phil
That's what I thought too, so I started checking into getting a extra fan cooled cooler to install. Turns out a lot of the ones that are available are not available for the 5/8" tubing found on the allisons. But then my shop talked to their mechanics and they all said that they normally see those temps on allisons because of the cooler in the rad. My truck does run about even with the water temp. Am trying full synthetic oil to see if it will run cooler, but no luck so far.
AFE Stage 2 Intake
B&W Turnover Ball
RollBAK roll tarp
