Old 09-04-2008, 06:29 PM   eBay Motors   #1 (permalink)
B--S
Points: 344, Level: 6
Points: 344, Level: 6 Points: 344, Level: 6 Points: 344, Level: 6
Activity: 0%
B--S's Avatar
weird tranny shifts
well my tranny is making weird shifts.
1^2 is good
2^3 is good
3^4 waits 3-400rpm higher to shift
4^5 waits 3-400rpm higher to shift
basically between 30 and 50 mph under "normal" acceleration it shifts higher than normal. coasting downhill it also upshifts and uses the tranny to brake which i never did before. and no it isnt in tow/haul, it feels like it though.
when the engine is cold it shifts fine, when the truck is accelerated using the cruise control "accelerate" switch it shifts fine. under hard acceleration it seems to shift fine but a couple times it will hang up in a gear.
i changed my fuel filter thinking it was the cause. both the oil and AT fluid are pretty fresh too.
still shifts weird after 2 weeks and noticed about 20-30 miles less out of a tank due to the high revving :S
2003 Silverado 2500HD CC/LB @ 213k km
4" turbo back, K&N kit, Fitch Fuel Cat... 20mpg mixed driving. 22-23 Highway
B--S is offline   Reply With Quote
Old 09-04-2008, 06:37 PM   eBay Motors   #2 (permalink)
blackdeath
Points: 4,559, Level: 28
Points: 4,559, Level: 28 Points: 4,559, Level: 28 Points: 4,559, Level: 28
Activity: 47%
Activity: 47% Activity: 47% Activity: 47%
blackdeath's Avatar
level is good right? when hot. if low even a bit sometime it can give you really weird symptoms.
2008 silverado dmax LTZ, aFe stage 2 ppe level 5, dpf delete, EGR block off plate , autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, fabtech tierods, 35"nitto a/t. 5" grandrock stack kit,straight piped
2008 traiblazer ss, straight pipe , 1.5" down
blackdeath is online now   Reply With Quote
Old 09-06-2008, 10:01 AM   eBay Motors   #3 (permalink)
B--S
Activity: 0%
B--S's Avatar
nope she's full of fluid and bright cherry red. im taking it in to get some front end work, might get them to check some codes on it to see why its acting up, it may need a new filter though. i believe they only replaced the fluid when the torque converter cracked.
Old 10-14-2008, 07:24 PM   eBay Motors   #4 (permalink)
B--S
Activity: 0%
B--S's Avatar
well i got it in and "apparently" my k&n filter oil had gunked up my MAF sensor causing the engine to store a code and drop power. the tech cleaned it out and instantly the shifts feel more solid, but there is the odd time it still runs "fast" but it is probably still relearning
Old 10-17-2008, 11:54 AM   eBay Motors   #5 (permalink)
usafracer
Points: 1,455, Level: 15
Points: 1,455, Level: 15 Points: 1,455, Level: 15 Points: 1,455, Level: 15
Activity: 67%
Activity: 67% Activity: 67% Activity: 67%
Give it at least 500 miles to relearn.
2008 GMC Sierra Crew Cab 4X4 334 hp and 599 ft/lbs on 24 Aug 2008 at Meridian Motor Sports Meridian Idaho.
2004 CC/SB 4X4 Duramax (sold)
