2002 2500HD Allison Problems - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 05-24-2011, 02:59 PM Thread Starter
I had this posted in the 911 section but wasn't getting much attention. The problem is a little less urgent now, as I have given up on getting this truck back on the road anytime soon. 2002 2500HD 8.1 4x4 gas with Allison transmission.
On a recent road trip, no load, i started having some tranny issues, once the tranny got good and warm. I would stick in first, or sometimes second. When it sticks in second, it acts retarded. When it sticks in first, everything is all good. With a little patience I can get moving again. I limped it home, drained fluid, and filled back up. Drove it 30 miles, drained fluid again, replaced spin on filter, and filter in the pan. My magnet is still in place on the spin on. Topped fluid back off, but the problem persists once the tranny gets warmed back up. Shifts and drives great until warm, then the next time you stop, it may shift 1-2, and kick back and stick in first, or shift 1-2-3, kick back into 2nd and all you have is 2nd until you shut the truck off. No first or reverse. Reverse blinks when its stuck in second. If it gets stuck in first, R will still work. I'm in a pinch and need to get this truck back on the road pronto. It might as well be undrivable until it is fixed. All my gear indicators light up so I'm not sure if my problem is the NSBU switch or not. SES codes are P0746 and P0776. I have done as much research as I could, posted on a gas burner forum with no luck. I have read a bunch of threads on here and performed a search, but didn't read anything that sounded like my problem. Is checking for a stuck solenoid easy? If it was stuck, wouldn't it be stuck all the time? It drives perfect until warm.
ChaseO is offline
post #2 of 8 (permalink) Old 05-24-2011, 03:53 PM
These two codes indicate that your clutches are not applying and releasing on time. Usualy this means a speed sensor problemat the turbine speed sensor ) on top of the case or the output speed sensor on the transfer case ( 4X4 ) or extension housing (2X4 ). Could also be a loose tone wheel in the transfer case. Could be wiring at either of the speed sensors.
Mike L. is online now
post #3 of 8 (permalink) Old 05-24-2011, 04:04 PM Thread Starter
Alright, how do i check that? I did notice the speedo gettin kinda jumpy here lately. The rear driveshaft has some play in it for sure. I believe there may be a bearing going out in the t case as well. Seems to be making a bunch of racket these days. I will start there and see what I can figure out. Thanks!
ChaseO is offline
post #4 of 8 (permalink) Old 07-11-2011, 08:21 AM Thread Starter
I wanted to update this thread in case anyone finds it in a search later or something. I found out what pump rub was, my t case was dry, and the internals to the speed sensor or tone wheel or something was messed up. Bought a new transfer case from jasper, bolted it in and problems solved.
ChaseO is offline
post #5 of 8 (permalink) Old 11-14-2014, 07:15 AM
My transmission gauge works until it gets to 200 then it flies to 285 and light comes on saying trans is hot. Had it flushed out and the shop told me trans looks great and did not smell burnt. When it does that the trans downshifts to first as a safety ,. It is a automatic trans.
al5831 is offline
post #6 of 8 (permalink) Old 11-14-2014, 07:33 AM
jc8825's Avatar
Al, your issue may be the gauge itself, not in the transmission.
NOTHING WORKS LIKE A CHEVY TRUCK.
SOLD:2007.5 Silverado 2500HD WT 4X4 LMM Victory Red
2005 R53 MINI Cooper S Hyper Blue Metallic
2006 R53 MINI Cooper Sa Dark Silver
jc8825 is offline
post #7 of 8 (permalink) Old 11-14-2014, 10:56 AM
Thank you jc8825! thats what i thought, everyone i tell it to says i need a transmission but it doesn't get that hot and it moves to fast when it hits a certain spot on the gauge. I was also thinking it may be a sensor. Do you know of a sensor for the gauge or trans.
al5831 is offline
post #8 of 8 (permalink) Old 11-14-2014, 06:45 PM
jc8825's Avatar
If your truck is an '03-'07, the clusters are faulty and need a rebuild. If you can do it yourself, parts are cheap. A speedometer shop could do it for no more than $200.
jc8825 is offline
