Hard shifting into gear - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 06-16-2011, 03:40 PM Thread Starter
ahduramax's Avatar
I noticed today that when going from park to drive or reverse, the shift isn't smooth anymore. It is like an abrupt jerk. Any ideas on what can cause this?
2007 CCSB LBZ
ahduramax is offline
post #2 of 10 (permalink) Old 06-16-2011, 04:32 PM
shotcaller660's Avatar
bump for ya
Josh-2006 lbz ccLb 4x4 @ 8080 lbs
Performance:diamond eye 5 inch, efi by rob,3 inch dp,Bd manifold,s&b,pvc,afe mp-plugged,air dog ll,edge cts,3 inch boost tube,ppe race valve,alligator trans lines,trans go,pump rub fix
Interior:
weathertechmats,clarion dvd head unit,12"subs,kenwood speakers
Exterior:tint,black lowpro toolbox,halo projector's,5000k hid,moog idler/pitt,rancho shocks,backup camera,cognito 7-9,35s,bmf novas,trac bars,iron bull bumpers,piaa lights
shotcaller660 is offline
post #3 of 10 (permalink) Old 06-16-2011, 05:29 PM
Administrator
jc1843's Avatar
First, check the U-joints-!
jc1843 is offline
post #4 of 10 (permalink) Old 06-16-2011, 05:33 PM
^i was going to say that but didnt wanna sound like a dumbass
Interior:
post #5 of 10 (permalink) Old 06-16-2011, 05:47 PM
FATBOY666's Avatar
When I was running my ppe it did that whenever I changed tunes. It would do it a few times then stop and go back to normal. Idk if that's your problem or not.
06 CCSB blue granite
20x10 hostile sprocket 305 nitto 420s
5" magnaflow 3" Mbrp DP
EFI from ATP
S&B cold air
Built trans from Mike L. Goerend ML-R
PPE Gen 3 tie rods PPE deep pan Suncoast filter lock
DHD trans brace and center link brace
Air dog 150, Fass fuel filter delete
PPE race valve and ported rail fitting
Merchant PCV reroute Kennedy egr block
FATBOY666 is offline
post #6 of 10 (permalink) Old 06-16-2011, 05:50 PM
Did you check the tranny fluid level? Might want to consider changing the Spin-on transmission filter and see whats in it or on its magnet.
'09 2500 Z-71 HD, Wyoming Edition
'06 Desert Fox TH
'53 Cranky Ex-Spouse
N8AGS
Len Todd is offline
post #7 of 10 (permalink) Old 06-16-2011, 06:20 PM
Banned
Change your spin on Alli filter, it is clogged causing a pressure change in the torque converter during engagement resulting in a clunk.
smokinlmm is offline
post #8 of 10 (permalink) Old 06-16-2011, 06:38 PM
evansdmax's Avatar
Not to highjack bit where can I get a magnet? Mine wasn't on the filter when I bought my truck
03 CCSB EFI + 5" STRAIGHT PIPE + 33X12.50 18S ON EAGLE ALLOY 197'S + 250K MILES
evansdmax is offline
post #9 of 10 (permalink) Old 06-16-2011, 07:12 PM Thread Starter
ahduramax's Avatar
I'll check that all out in the morning. Thanks y'all. It prolly needs a filter.
2007 CCSB LBZ
post #10 of 10 (permalink) Old 06-16-2011, 07:31 PM
Specialized89's Avatar
Can get a magnet off of one of the vendors, GM, or an Allison dealer.
Specialized89 is offline
