Gear vendors o/d units - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 06-25-2011, 06:52 PM Thread Starter
45Colt45's Avatar
Part #3D0261A $3395.00
Automatic 5-6-Speed NV 261/263 Big Block Gas "Allison".
Replaces rear transfer case housing.
2001 and up big block gas.
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
http://www.irinfo.com/overdrive/gv.pdf
I just wanted to hear what anyone had to say about the units. I have wanted one for years, but am going to wait until I get my LBZ. Let me know what you have on them, thanks
Colt
-Colt-
2009 2500HD, 4X4, CCLB, SRW, LTZ.
Bone Stock for now.
45Colt45 is offline
post #2 of 8 (permalink) Old 06-25-2011, 06:57 PM
Administrator
jc1843's Avatar
I doubt the OD unit will handle the torque of the D-Max.
jc1843 is offline
post #3 of 8 (permalink) Old 06-25-2011, 07:03 PM Thread Starter
45Colt45's Avatar
I was trying to find the details on torque, but the BASE UNIT will handle 1200+HP, and 30,000 Lbs GVW. You can order kits that will handle over 2000 HP, so I am pretty sure that it will handle the torque??? I am interested to find out more about the unit.
-Colt-
Bone Stock for now.
45Colt45 is offline
post #4 of 8 (permalink) Old 06-25-2011, 07:05 PM
SteepyBS's Avatar
i dont think the O/D unit would be much help, with the double overdrive the 6 speed Alli already has this would probably put your rpms way out of the power band
however the U/D might be useful for BIG loads
03 Chev CCLB
500HP on STOCK trans/fuel/turbo
built trans and lift pump coming soon!
special thanks to
ADP, ATP, HDP, UDP, BDDP, MJS
SteepyBS is offline
post #5 of 8 (permalink) Old 06-25-2011, 07:15 PM
danhr's Avatar
Will it hold? yeah.. probably
but you will engage the over drive unit for each of the 6 (or 5) gears.... making your allison a 10 or 12 speed transmission.
but only one of those gears is going to be taller than your tallest over drive unit
2007.5 2500HD CC/SB LTZ
498 rwhp, 845 rwtq
DiamondEye 4", EFI Live by BobO, Edge Insight CTS, S&B Intake, Bilstein 5100 shocks, MOOG idler/pitman with SS support, Raptor 150, P553207, !PCV, !EGR, Transgo Jr, Rare Parts tie rods, 55 watt 4.5k HID low/hi/fogs, Belltech 3" lowering shackle
danhr is offline
post #6 of 8 (permalink) Old 06-25-2011, 08:08 PM
gmpacnw's Avatar
These units will easily handle the torque & hp.
Not gonna help ya much unless you have gears 4.XX-5.XX. The 6 speed with 3.73's is plenty good.
Why are you wanting one?
2007 Silverado Classic K2500 HD, ECLB, 4" Banks cat-back, ATX Mojave Teflons wrapped in 265 x 75 x 16 Goodyear Silent Armors.
Restored 1972 Cheyenne K10 Long Bed, GMPP Stroker, overdrive behind Turbo 350 & trans case, 3.73 gears, the list goes on.........
gmpacnw is offline
post #7 of 8 (permalink) Old 06-26-2011, 10:56 AM
I have not seen one installed in a duramax but I have had to replace 2 main shafts ( GV ) behind stock Cummins. They snap pretty easy.
Mike L. is offline
post #8 of 8 (permalink) Old 06-26-2011, 10:56 AM
My understanding was that those units are not for diesels since engine braking will damage the unit.
If you want overdrive, then get the suncoast 5-6 spd tranny conversion instead.
MTL_Dmax is offline
