Old 09-20-2008, 01:00 PM   eBay Motors   #1 (permalink)
Ridin'GMC
Points: 1,703, Level: 16
Points: 1,703, Level: 16 Points: 1,703, Level: 16 Points: 1,703, Level: 16
Activity: 15%
Activity: 15% Activity: 15% Activity: 15%
Ridin'GMC's Avatar
5 speed or 6 speed tranny?
is the 06 lly tranny a 6 speed or a 5 speed? I know that the LBZ has a 6 speed tranny but i am uncertain if the 06 LLY has the 6 speed tranny. it seems like my LLY does because when i put it in manual shift, it shows 6 gears instead of 5. when it is in auto, it doesnt even feel like 6 gears to me.
2006 Chevy Silverado 2500HD crew cab with a LLY
6" RCD suspension lift rollin' on 20' Driv wheels and 325 nittos
Engine all stock for now
Ridin'GMC is offline   Reply With Quote
Old 09-20-2008, 01:02 PM   eBay Motors   #2 (permalink)
FH Leader
Points: 1,189, Level: 13
Points: 1,189, Level: 13 Points: 1,189, Level: 13 Points: 1,189, Level: 13
Activity: 24%
Activity: 24% Activity: 24% Activity: 24%
FH Leader's Avatar
it is a 6 speed the 5 speed trannys did not have the manual mode.
Four stroke diesel S.S.B.B. Suck Squeez Bang Blow
06 LBZ with 5 inch magnaflow exhaust,Bd exhaust manifold, Bully dog outlook, Egr blocker, Firestone air bag system,Custom sound system, dual fuel filters,leveling kit, B&M deep tranny pan,TTS lift pump,Turbo Resonator plugged,Cooper ST 265/75R16, Bully nerf bars and B&W guardian headache rack sprayed with reflex bed liner, B&W turn over ball,B&W Tow&Stow, transgo jr, efi live, tranny filled with transynd
Omaha Truck and Trailer offering Woodworth custom build trailers.
Now a factory authorized Whelen dealer
My iron is yellow
FH Leader is offline   Reply With Quote
Old 09-20-2008, 10:36 PM   eBay Motors   #3 (permalink)
Tow Master
Idiot lookin at the computer
Points: 12,414, Level: 48
Points: 12,414, Level: 48 Points: 12,414, Level: 48 Points: 12,414, Level: 48
Activity: 90%
Activity: 90% Activity: 90% Activity: 90%
Tow Master's Avatar
I honestly never thought of it but I think just the year 06 has a 6 speed. Doesnt matter what motor. But if your indicator says 6 in manual mode then im sure you have a 6 speed! Congrats!
Jason
Old 09-20-2008, 10:40 PM   eBay Motors   #4 (permalink)
daddysLBZ
Highway travler!!
Points: 6,295, Level: 33
Points: 6,295, Level: 33 Points: 6,295, Level: 33 Points: 6,295, Level: 33
Activity: 47%
Activity: 47% Activity: 47% Activity: 47%
daddysLBZ's Avatar
Question is this thing working right???
If it shifts four times=5 speed.
if it shifts 5 times=6 speed
Umm,wonder which one I have??better check on that NOW!!!
MINE2006 GMC 2500HD4x4 sb cc LBZ!Got a couple lil mods,more to follow
[color="Blue"]02 GMC 1/2 ton,2wd,5.3 power{Mama's ride}
87 SS Monte Carlo 77k[orig!]
78 Malibe [2dr.]350/350
WORK RIG:03 YukonXLHypertech tuned!!310k miles!
The left lane is used to pass,so get over,or we'll run over ya asssss!!1996 Impala SS on the way!!!
Old 09-21-2008, 02:08 PM   eBay Motors   #5 (permalink)
Ridin'GMC
Activity: 15%
Ridin'GMC's Avatar
well thats awesome that i got a 6 speed tranny, is it true they can handle abuse a little bit better than the 5 speed does? like putting 100 hp, although it is not recommended. will a shift kit handle 100 hp increase or should you keep it under 90 for a tuner?
Old 09-21-2008, 04:29 PM   eBay Motors   #6 (permalink)
justinv
Points: 820, Level: 11
Points: 820, Level: 11 Points: 820, Level: 11 Points: 820, Level: 11
Activity: 0%
justinv's Avatar
the 5 speed didnt have the manual mode only the 6 speed. 6 speed will handel little more abuse than the 5 speed. you can put the transgo jr kit in it to help out the life for awhile depends on what you want to do with the truck the transgo jr kit is like 100.00 dollars
2007 Chevy Classic LBZ, AFE stage 2, Turbo back 5 Inch Magnaflow, EGR block off plate, PPE lift pump, PPE pick up tube out of the tank. Got the efi live tuning from fleece performance on my truck now it is a great tune getting the transgo jr. kit for now
justinv is offline   Reply With Quote
Old 09-21-2008, 05:42 PM   eBay Motors   #7 (permalink)
BigRedChevy
Post Slut
Points: 10,854, Level: 45
Points: 10,854, Level: 45 Points: 10,854, Level: 45 Points: 10,854, Level: 45
Activity: 100%
BigRedChevy's Avatar
With the transgo Jr. kit you can run 100-120 HP safely.
KYLE
Old 09-21-2008, 06:42 PM   eBay Motors   #8 (permalink)
blackdeath
Points: 4,559, Level: 28
Points: 4,559, Level: 28 Points: 4,559, Level: 28 Points: 4,559, Level: 28
Activity: 47%
blackdeath's Avatar
if it shift 4 times its a 4 speed , 5speeds has 5 speeds . and 6 has 6,, 4 th gear 1to1 ratio 5 and 6 overdrives
2008 silverado dmax LTZ, aFe stage 2 ppe level 5, dpf delete, EGR block off plate , autometer gauges (cobalt) boost and pyro,, transgo jr ,, 8"fabtech, fabtech tierods, 35"nitto a/t. 5" grandrock stack kit,straight piped
2008 traiblazer ss, straight pipe , 1.5" down
blackdeath is online now   Reply With Quote
Old 09-21-2008, 06:49 PM   eBay Motors   #9 (permalink)
timespentsearching
Points: 4,010, Level: 26
Points: 4,010, Level: 26 Points: 4,010, Level: 26 Points: 4,010, Level: 26
Activity: 35%
Activity: 35% Activity: 35% Activity: 35%
timespentsearching's Avatar
only 4 in a 5 if you dont could putting it into drive.
Diamond Shocks
Tuner: Banks Six-Gun with PDA
Exhaust: Diamond Eye 5 inch system
Airtake: modded stock box (banks with scoop in the future)
Turbo: Stock, PPE boost valve
Transmission: Stock,
Tires: 235/85R16 Firestone transforce AT
timespentsearching is offline   Reply With Quote
Old 09-21-2008, 06:57 PM   eBay Motors   #10 (permalink)
BigRedChevy
Post Slut
Activity: 100%
If it shifts 4 times it is a 5 speed. You are alread in 1st so theres not a shift to count. The first shift you feel is 2nd.
KYLE
