i bought a ppe boost valve off ebay and installed into my truck. It didnt change my boost at all, still getting 20 psi same as stock. whats the deal here?
__________________ 2002 CHEVY 2500HD, PPE BOOST VALVE, POWER FLOW INTAKE, PPE STANDARD XCELERATOR, IDEL CONTROL, GLOW SHIFT BOOST GAUGE AND EGT GAUGE, 285/75-R16 TIRES, MUFFLER DELETE. DINKERS
not to sound like an ass but did you install it in the right direction??? mine works great. look at the arows I think they point to the turbo waste gate if it is in right look for holes in the inter cooler line by the power steering hose mine runs about 28 with valve at no tune and 32+ with by biggest tune
__________________ 2002 CREWCAB DUELLY 4X4 6SP MANUAL WITH SUPERCHIPS,SBC single mass/disk flywheel,ppe boost valve, K&N , MUFFLER DELEATE OPP. AND CROME FLAME GRILL
mine works great too. make sure you check the hose clamps on all the piping. from the turbo to the intercooler there could be a leak somewhere.
__________________ 04" lb7 CC 4x4 black cuz it gets better MPGs. PPE programmer on 90hp, PPE valve, and air box mod. plugged all the right holes in the intake. intake elbow mod (.450) and polished out. max power headlight mod, no more kat. lots of wax on the hood to help with better mpgs.
i just noticed that leterpour has a turbo x boost controller. maybe that needs to be adjusted. i thought that anything over 32psi is not safe unless you do more work to your motor and trans
why did you get the boost valve when you have the banks wastegate, you know you can adjust the banks wastgate to get more boost. just a thought.
and to answer the first question i dont think you will get much more boost than stock without some kind of aftermarket tuning.
Because adjusting the banks big head wastegate to get more boost can change the rate at which the wastegate opens and can cause surging, thee is not as much of a risk with the ppe.
