batmowheel and bigger injectors??? - Page 4 - Chevy and GMC Duramax Diesel Forum
Turbo's Stock and Aftermarket. Place for all your turbo questions
Old 01-25-2013, 08:09 PM   eBay Motors  #31 (permalink)
e46_330i's Avatar
Originally Posted by HDdave View Post
Man you can make some stupid power with that batmo lly charger. You oughta be in the low 600's with .40's
I thought batmo's were only good for 30whp more or so Dave? If not, this is pleasant news
2004.5 Sierra SLT 4WD CCSB Black/Black
Studded, Deleted, Re-Routed
FPRV Race Valve
LBZ FPR
20x10 ET -12 Fuel Hostage
Nitto 420s 305/50/20
All-On Mod
MA Pump Rub Kit
3" DE Down Pipe to a 7" Single Mitre Cut
EFI Live DSP5 By Kory "Supa Tuna" Willis @ PPEI
e46_330i is offline   Reply With Quote
Old 01-25-2013, 08:55 PM   eBay Motors  #32 (permalink)
I-6 killer
HDdave's Avatar
Depends the application really.. Lot of guys played around with them for a while but its looking like the best setup is an LLY charger (the biggest...) with a batmo on any of the vgt trucks.. I know a couple guys running them with Korys tunes. They are mean.. A set of injectors would help it for sure, but with that lbz reg you could still do pretty well!
Much easier to get to when the trans is out too btw...
05 LLY
BLACK
Air/Fuel/Stance
Thanks to:
Caleb @ Blackout Performance
Kory @ PPEI
HDdave is offline   Reply With Quote
Old 01-25-2013, 09:07 PM   eBay Motors  #33 (permalink)
Danville put down I yjink like 630 with batmowheel. I personaly picked up. A ton of top end power with my install runs great with 40%
2003 duramax-efi live (tuned by me),100hp lightening nozzles, fass, cold air, 5in farmboy diesel exhaust, mild built tranny(trans go deepdish pan and clutches),with 1056 suncoast
1994 6.5- cold air intake,4in exhaust, 3 in down pipe, #9 ssd resistor, 80hp ssd chip, marine injectors, south bend clutch, solid mass flywheel
03dirtylb7 is offline   Reply With Quote
Old 01-26-2013, 07:56 AM   eBay Motors  #34 (permalink)
e46_330i's Avatar
HOPEFULLY, you'll be getting a text maybe this fall about a PPE Stage V as long as my balance rates are solid. We shall see!
FPRV Race Valve
LBZ FPR
All-On Mod
MA Pump Rub Kit
Old 01-26-2013, 07:59 AM   eBay Motors  #35 (permalink)
I-6 killer
HDdave's Avatar
Mine are still solid at 140k even with my .45 overs! Hopefully yours look good!
05 LLY
BLACK
Air/Fuel/Stance
Thanks to:
Kory @ PPEI
Old 01-26-2013, 08:02 AM   eBay Motors  #36 (permalink)
e46_330i's Avatar
I've never had a smoking issue and no fuel in the oil after 5k miles so we'll see. Just need to find time to to steal Jordan's CTS lol
FPRV Race Valve
LBZ FPR
All-On Mod
MA Pump Rub Kit
Old 01-27-2013, 05:12 PM   eBay Motors  #37 (permalink)
05llydirtyy's Avatar
im on stock injectors and a batmostocker and my truck dynoed at 596 without my lift pump working and on 20s and 36s, now its back working and changed tuners its over 600but injectors are my next thing, i believe it would make a big change
A few mods here and there, Its slow
Thanks to
Sam and Dave @ SSDP
Kory Willis @ PPEI
05llydirtyy is offline   Reply With Quote
