| Turbo's Stock and Aftermarket. Place for all your turbo questions |
| | eBay Motors #21 (permalink) | ||
| Longbeds FTW Join Date: Oct 2008 Location: Natrona Heights, PA
| Quote:
Lets see some videos of that thing! Quote:
I have a bone stock CP3 with 134,000 miles and 40% nozzles.
__________________ 06 Dmax/Allison EC/LB 4x4 TTS PowerLoader III • full billet Bully Dog stage 7 • BCI 7" intake with custom snorkle • fender vents • quintuplet shotgun cat stacks • 22" Rockstars • Huge "Dirtymax" sticker • -60% nozzles • extra pcv with dual catch cans • compounded EGR • silencer ring MIA • 4.56 gears • Lowered 5.5" in the back • Lifted 6" in the front • Monster sticker • flat bill mod • 8' CB whip • blacked out reverse lights • gauges everywhere 08 BMW 528xi 00 Buick Regal GS | ||
| Hang it!...Fire! ![]() Join Date: Aug 2009 Location: Tacoma, Washington
| im hung up on the s472, im just wondering if i should stick with a smaller s366 or a larger than stock vgt turbo because of emissions.
__________________ Max - 07 LBZ ECLB LOWERED! Plugged, Rerouted, Blocked, PPE Mod, DE 5 inch, DE 3inch DP, EFI Live DSP-5 by IDAHO ROB, Insight, Raptor 150, Transgo Jr, Nicktane, PROEFX Steel Roll Pan, XD Revolvers -24 Offset 20x10 w/ 305/50 Nitto 420s, Alligator Sleeves, Belltech 3inch drop shackles, T Bar bolts all the way out, DDM Tuning 6000k Low/3000k Fog, and about 50lbs of Zipties |
| | eBay Motors #23 (permalink) |
| Duramax Lifetime Supporter Join Date: Jan 2011 Location: Meridian, MS
| So at what point is the decision made to build the bottom end other than by it blowing up, anything over stock? I understand it needs to be done.. but, there are some people running alot more charger than stock on stock internals, yes, it's way more risky but there has to be a more defining point to say this turbo will work and this turbo is pushing it and there is no way in hell with this turbo, etc... I just don't want to spend the money on a 4094 if it's not a good choice and I don't want to buy one that's gonna grenade my motor.. so what do y'all suggest?
__________________ MATT - 2006 GMC 2500HD 4X4 CC/SB SLT - LBZ "CMNSKLR" ADII 165, MA PUMP RUB, PLUGGED, RE-ROUTED, BLOCKED, K&N, CUT BOX, PPE FITTINGS, RACE VALVE, & FEED LINE, 5" STRAIGHT EXHAUST, 8" TIP, KRYPTONITE CENTERLINK & TIE-RODS, COGNITO BRACES, END LINKS & GUSSET, MOOG ARMS & JOINTS, LEVELED W/ KEYS, 20X10 AE 511's, 33X12.50 TOYO M/T's, FRONT BUMPER BUILT BY ME, RECON SMOKED CABS, TAILS & 3RD BRAKE LIGHT, BILSTEIN 5100'S, LINE-X, ETC. DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| DuramaxForum Veteran Join Date: Mar 2011 Location: Pine Bush, New York
| DMAXchris where did you get yours from? I was looking at Danvilles website
__________________ Andrew 2006 2500HD LBZ ECSB, EFI Live V2 DSP5 by Diesel Addiction | K&N CAI w/ Amsoil Nano | Banks Technicooler | Flo~Pro 5" TB | DE Downpipe | Phantom IIs | Blocked/Rerouted/Capped | Nictane w/CAT Filter | PPE Ported Fuel Fittings | AirDogII | CCM 2'' Lift w/ Rear Blocks | Nitto Terras | Recon Cab Markers | DDM HIDs | 15% tint | BOSS 8'2'' V Plow DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| Directly from Bullseye Power through my local diesel hotrod shop. Danville is a Bullseye dealer so they can take care of anything you want.
| Senior Member Join Date: Feb 2010 Location: Western PA
| No video but heres a crappy pic of my current setup: ![]() billet 366, currently running stock LBZ CP3 with 40% injectors. I just added profab manifolds and it really helped the turbo spool up. my cruising boost is down a few rpm over my batmo stocker. drive pressure is right at 1:1, egts at cruise are at 7-800, slightly lower than stock(that was before the manifolds).
__________________ 2007 GMC 3500 LBZ- built trans, billet 366, dual pumps |
| | eBay Motors #27 (permalink) | |
| Quote:
| | eBay Motors #28 (permalink) |
| DuramaxForum Enthusiast ![]() Join Date: Apr 2010 Location: Boonville, MO
| Ohh and an s464 is enough to blow head gaskets, I know from experience lol..I don't have the truck back yet, should be done this week and going to get it this weekend hopefully!! I will have my wife take some videos or something.
__________________ 2006 LBZ CCSB 04.5 LLY RCLB ZF6 -FOR SALE 04.5 LLY CCSB -SOLD Thanks to: ADP, NCT, MA, DmaxStore, Creatures of the Night http://www.dmaxstore.com/ |
| | eBay Motors #29 (permalink) | |
| Quote:
The set-up on your truck is pretty much my main goal... minus the expensive goodies inside.. for now
__________________ MATT - 2006 GMC 2500HD 4X4 CC/SB SLT - LBZ "CMNSKLR" ADII 165, MA PUMP RUB, PLUGGED, RE-ROUTED, BLOCKED, K&N, CUT BOX, PPE FITTINGS, RACE VALVE, & FEED LINE, 5" STRAIGHT EXHAUST, 8" TIP, KRYPTONITE CENTERLINK & TIE-RODS, COGNITO BRACES, END LINKS & GUSSET, MOOG ARMS & JOINTS, LEVELED W/ KEYS, 20X10 AE 511's, 33X12.50 TOYO M/T's, FRONT BUMPER BUILT BY ME, RECON SMOKED CABS, TAILS & 3RD BRAKE LIGHT, BILSTEIN 5100'S, LINE-X, ETC. DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource | |
| | eBay Motors #30 (permalink) | |
| Junior Member Join Date: Jul 2007
| Quote:
Just so I'm clear, 45lbs of boost and 80mph is "rolling into it like normal"? ![]() hahaha, truck sounds good bro.
__________________ 04 CC SB LLY More Air, More Fuel, More Power, More Better!....more expensive ![]() My Truck pics | |
