turbo to choose? - Page 2 - Chevy and GMC Duramax Diesel Forum
Turbo's Stock and Aftermarket. Place for all your turbo questions
Old 01-06-2013, 08:12 AM   eBay Motors  #11 (permalink)
An s480 is going to be really laggy. My gt42 will tow a little but I wouldn't want to be hauling every week with it.
2007 GMC Sierra 2500 LBZ. exteneded cab short box.
Ridge Runner Tuned
Built motor and trans.
Garrett 4202.
PPE Dual Fueler.
RDL Manifold, up pipes.
Tie rod sleeves, Straight Centerlink and braces.
B-Weir is offline   Reply With Quote
Old 01-06-2013, 08:31 AM   eBay Motors  #12 (permalink)
Banned
Call Mark at Danville Performance and get him to set you up with a charger...
smokinlmm is offline   Reply With Quote
Old 01-06-2013, 08:48 AM   eBay Motors  #13 (permalink)
DmaxMonster's Avatar
Thanks I will look him up and call him Monday. I hear the 480 batmo isn't that laggy. I found some people running the 475batmo with the 6.6 and 40over injectors and said it was highly streetable with the right tuning.
2011 LML ecm converted to lmm 4x4 CCD PPE mans, up pipes, 5" exhaust, 250Fass lift pump, EFI live, Focal K2s all around two JL 13" PS2 flip down in back S475, and dual CP3 custom built tran thanks to the help and savings from Tim Heckler Ballies, Sam at Southern Style Diesel, Mark at Danville, Tony at All season, Guy at Socal, Mike L, and all the people on the df
DmaxMonster is offline   Reply With Quote
Old 01-07-2013, 07:36 AM   eBay Motors  #14 (permalink)
Rifleman3's Avatar
Im not sure if Newly has sold his twin kit yet but that kit would get you to 1000hp with some fabing of the kit
2002 GMC Sierra 2500
Comp Truck
2004.5 GMC Sierra
AirDog II 165, PCV reroute, EGR Blocker plate,EFI Live tuned by Rob at ATP
Soon to come Built Tranny, Head studs, Maybe bigger turbo or twins.
http://www.atptrucks.com/
"Live by a gun,Die by a bullet"
Rifleman3 is offline   Reply With Quote
Old 01-07-2013, 07:44 AM   eBay Motors  #15 (permalink)
*The Solder King!* \m/ \m/
n0useforaname's Avatar
Sled Pulling vs. Towing = apples and oranges. IMO if you want something that is streetable, fun, and tows well... get yourself a twin setup. Different people have different opinions... some like singles, some like twins, etc.. I don't think you'll get one straight answer. And am I understanding right, you are converting your LML to an LMM? Wouldn't it be cheaper to just sell the LML and buy an LMM?
RIDE: 2007 Chevy CCSB LBZ colormatched Black Pearl
LIFT: ZONE, Kryptonite Front end, Cognito Brace kit, Traction Bars, Comp. Tubes
TRANS: Big Dipper Stage IV/PPE Deep Pan / Pump rub fix
SOUND:X4500BT, 6 1/2 JL Audio's, 10"s, 5 Channel JL AMP
INTERIOR: EGT/Boost Autometers & CTS, Black Cherry Denali Trim and wheel, Black Leather, Red L.E.D's, US Speedo Cluster, Rubber Floor, 20% tint
ADD ONS: 40 overs, AD II 165, Oasis Diff, Roll pan, Merchant brace, BigChevyHitch, Cowl Hood, 4500K HIDs, AMP Research Steps, LM Grille, BedRug w/ Recon lights, ExTang Solid Fold, LED tails
TIRES/WHEELS: 35X12.50-20 Toyo MT on 20x10 BMF S.O.T.A's and 4.56 Gears
AIRFLOW: EPR Triples, Turndown, AFE intercooler pipe, EFI LIVE by ATP
INSTALLER: BLACKOUT PERFORMANCE
Old 01-07-2013, 08:09 AM   eBay Motors  #16 (permalink)
ripmf666's Avatar
X2 would be a lot cheaper and smarter. If worried about cost of what the 4202 would cost I would stop now. Also here is a billet 4202 GTX4202R
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live Idaho Rob,MPI Twin's installed by BigDipper,PPE Twin Cp3's,PPE lift pump,Dipper 30% injectors, updated BigDipper Trans Precision ML converter.
Alot Of thanks To Joe & Dan at PPE,George aka BigDipper
11.53 @ 116.92 1.66 60's
RIP LBZ 6/1/08@5:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
Custom ECM & TCM Tuning for 2001-2010 LB7/LLY/LBZ/LMM trucks
by Tony Martino at Ridge Runner Diesel available here-
EFI Live Products
ripmf666 is offline   Reply With Quote
Old 01-07-2013, 10:02 AM   eBay Motors  #17 (permalink)
was looking for a all around good turbo for now to twin later but for now would be giving me the most hp i can get yet still be able to tow...I could not find a LMM that I wanted with the options i wanted when I got mine. I talked to Mark at danville smart guy. We decided to go with a S475 87mm batmo. should work well for what I am after. I will keep you all up to date on how it works out. Thanks everyone you you help.
Old 01-07-2013, 11:23 AM   eBay Motors  #18 (permalink)
chadbaker's Avatar
is the only reason your converting to LMM the EFI capabilities? seems like a mess of trouble
2012 GMC LML 2500HD Texas Edition ccsb
DPF delete, 4"MBRP turbo back exhaust
H&S XRT pro FASS 150gph
ISS pro factory matched EV2's
2" leveling keys and Bilstein leveling shocks
18 yrs old H-TOWN TX 713.
chadbaker is offline   Reply With Quote
Old 01-07-2013, 02:00 PM   eBay Motors  #19 (permalink)
The block.is the.best one gm has made yet, the frame is the most solid the trany has the bigest oit put shaft of the past years, the dually bed sides are real metal. It one of the most solid trucks gm has put out imo minus the dpf,egr,dfp, and ecm crap...i wanted.a lmm but some times u have to make do woth what you.have..that amd i want 1,000+rwhp.. I dout you will be getting that with any tuner in the next couple years at best..they will make promises but add a year to 6months to that. I just.got.tierd of waiting. Once i do it and have the bugs worked out i most likely wont be the last.
