Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods. > Turbo's Stock and Aftermarket.
Turbo's Stock and Aftermarket. Place for all your turbo questions
Old 02-11-2009, 10:28 PM   eBay Motors   #11 (permalink)
Dmax15
Dmax15's Avatar
Yeah a DIY twin turbo kit. I couldn't imagine how long the write up alone would take. Pictures and stuff of the process would be cool though.
2002 GMC LB7
EFI live tuning from IdahoRob
http://www.atptrucks.com
12.34 @ 108.7mph
Dmax15 is offline   Reply With Quote
Old 02-11-2009, 10:30 PM   eBay Motors   #12 (permalink)
duramaxxin73
duramaxxin73's Avatar
Hey someone has to do it eventually
2004.5 Chevy Silverado 2500HD Duramax LLY
*Suncoast Stage IV w/ATS Five Star Torque Convertor w/Co-Pilot. 7" Mitre cut Stack w/ Hush Power muffler, tie rod sleeves and center link, Fass 200, Modded dual DP LBZ cp3's, E-Locker, 60% nozzles, Danville Performance Stage 2 65mm Turbo. *
11.93@ 109mph on 35's
EFI Live Tuned By Mark Broviak
2006 Chevy Silverado 2500HD Duramax LBZ
aEm intake, MBRP 5" exhaust, no tuning for now!!
duramaxxin73 is offline   Reply With Quote
Old 02-11-2009, 10:30 PM   eBay Motors   #13 (permalink)
timespentsearching
timespentsearching's Avatar
Originally Posted by duramaxxin73 View Post
When you start your project you should do a write up and take pictures and post it in the DIY section of the forum
will do for sure. it will probably take a month or so to do. try and built it in june and yearly july. as soon as the snow melt and sled go by by im getting the suncoast in. as soon as the banks goes im getting EFI LIVE. then need guages, airdog, tierod, pitman support, and then the turbo and start making the pipe. only thing im worried about it oil hook up and the wastegates.
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
Old 02-11-2009, 10:33 PM   eBay Motors   #14 (permalink)
timespentsearching
haha, wont be to bad. you should see some of the suspension writups i do on sleds and talking about valving. got 20 pages on info going back and forth on a mod to a polaris prox suspension and tuning for it. i can make it worth everyone's time. now does anyone have a use s475 or s478 turbo around? dont know which to go with, the s475 is only 600 buck, s478 is 900. i can get to a/r's 1.10 or 1.32
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Old 02-11-2009, 10:58 PM   eBay Motors   #15 (permalink)
duramaxxin73
Thanks Freddy and good luck with the build.
Old 02-11-2009, 11:01 PM   eBay Motors   #16 (permalink)
timespentsearching
thanks guys well its set, compounds here i come. i must alway like the hard way around things, haha. i look at it this way, learn a ton and save 3000, sounds good to me. anyone in the ND or MN area that want to come hang out this summer and help?
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Old 02-12-2009, 08:18 AM   eBay Motors   #17 (permalink)
timespentsearching
what do you guys thing here for a large turbo. im between 2 turbos. the B2 s400 is 650, 74.5 compressor wheel 1.32 a/r. the s475 is 600 bucks and has a 75mm compressor wheel i can get 1.10a/r or 1.32a/r. the s478 is 880 with a 78mm compressor wheel and 1.10a/r or 1.32a/r. any guys that know a little more aobut turbos want to give me a little advice. also wastegate, 40mm or 50mm? i think i can get away with a 40mm
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Old 02-12-2009, 08:32 AM   eBay Motors   #18 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
isnt bigger always better?lol
good luck with the build..
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 02-12-2009, 08:36 AM   eBay Motors   #19 (permalink)
timespentsearching
thats what she said, hahah. well i just dont know if its worth going to a s478. i dont know if i can make it worth while. if i had a bd or htt as a smaller turbo them ya, then again im thinking of upgrading to on in the future so many do the bigger turbo them?
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Old 02-12-2009, 08:40 AM   eBay Motors   #20 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
with the stock turbo i would prob say stay with the S400 or S475 or else your offset between the 2 will be hard to work with when setting it all up.
James
Business Truck
DD/Beat Around
Economy Saver
