well ive been doing turbo research for like the last 4 months on what i want to do this summer. the more i think, the more i want to do a compound setup. just talked to a guy on DP that built his one (almost the exact same as MPI's setup) using the stock IHI turbo and a s472 (id probably use a s475) and he is making move 600HP with 45 lb of boost. he is only spinning 15-20 psi added in the IHI so the wheel is not over spinning and the housing can take the boost, just the wheel can not. im thinking i can build the whole thing for under 2000. i may spend 50 hours doing it but i think it will be worth while. what do you guys think? i think im going to try and plan it out and get most of the parts done and then take a long weekend to install and finish it all off in the pickup. i have to make all the pipes myself unless i can find some MPI pipes around and just cut them to fit the lb7. good idea, bad idea, what do you think. my dad will think im crazy but thats ok.
__________________ Pickup: 03 GMC 2500HD EXT Cab Long Box
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
I say go for it, sounds like you've done your research and have it figured out. When you are finished it'll be quite a feeling knowing that you fabricated your own twin turbo setup
__________________ 2002 GMC LB7
yep i think it will be fun, then if i want to go bigger the following summer i can stick a larger turbo on there as well, id have to remake the pipe but jsut welding new ends on is easy. run the IHI this summer nad switch to a HTT the following
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Aluminum tubing?
Yeah I was talking about intake tubes. Have an aluminum welder? Although bending them isn't much of an option if its aluminum. Steel might work best. What does MPI use?
yep had weld about anything. i got stick, mig (steel and alum) and tig if needed. i dont know what nate uses. id like to get my hands ona set of tube though and turbo support to make my life easier
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
*Suncoast Stage IV w/ATS Five Star Torque Convertor w/Co-Pilot. 7" Mitre cut Stack w/ Hush Power muffler, tie rod sleeves and center link, Fass 200, Modded dual DP LBZ cp3's, E-Locker, 60% nozzles, Danville Performance Stage 2 65mm Turbo. *
11.93@ 109mph on 35's EFI Live Tuned By Mark Broviak
2006 Chevy Silverado 2500HD Duramax LBZ
aEm intake, MBRP 5" exhaust, no tuning for now!!
thanks man. ya i really like projects, probably like working on stuff more then playing with it, im weird. id be overly happy with 575 hp but i think i can make even more. lets jsut say i tune it to 42 PSI im gettimg 12 psi more boost then i got know and who know how much more air over just the single. i can also run way more hp towing and be safe.
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
