Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > After Market Mods. > Turbo's Stock and Aftermarket.
Turbo's Stock and Aftermarket. Place for all your turbo questions
Old 08-27-2009, 08:12 PM   eBay Motors  #11 (permalink)
trevorb_06's Avatar
Originally Posted by Hondarider552 View Post
remove compressor and turbine wheels as redBowTies stated, leave turbo vanes intact so you have a whistle far superior than a 747.
So taking out those wheels has no loss in power or mechanical down fall?
Just an increase in turbo whistle?
http://www.myspace.com/trevor_06
http://www.facebook.com/home.php#!/p...?id=1370314361
Truck: 02 LB7 Chevy 2500HD 4x4 Crew Cab Long Box LT
Add-ons: Reflexxion Ram Air Style Cowl Induction Hood, 285/75/16 Wildcat EXT, Spray on Bed Liner, Firestone Rear Airbags
Performance: Banks Ram Air Intake, 3.5" Straight Pipe, PPE Boost Increase Valve, Turbo Intake Horn Mod
Wish list: Too long to list!!!
www.getsomeperformances.com
trevorb_06 is offline   Reply With Quote
Old 08-27-2009, 08:26 PM   eBay Motors  #12 (permalink)
1600 pulse width rocks
Hondarider552's Avatar
I was joking
Brian. LBZ fitted with one off parts.
ABQ Diesel Dragz March 20th, ABQ, NM gattes at 8am.
Old 08-27-2009, 08:33 PM   eBay Motors  #13 (permalink)
GWEEDO!!!!
RedBowTies88's Avatar
lol dude....you should google "how a turbo works" good bit of into to have on ya
Beech (thats my real name) EfiLive by Nick@duramaxtuner, likes to go fast
CC/SB LLBYE
Originally Posted by DMAXchris View Post
No one ever said anything about lube or salami you sick bastard.
RedBowTies88 is online now   Reply With Quote
Old 08-27-2009, 09:07 PM   eBay Motors  #14 (permalink)
SPARK PLUGS SUCK!
Buck's Avatar
you guys are bad!!! im sure what you mean is blocking the resonator with a test plug. do a search for "resonator plug" on this site. oh ya if you couldn't get Google to work here ya go bud!!
YouTube - Holset - How a Turbocharger Works
Vehicle 2008 Black Chevy Crew Cab Short Bed Z71
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods EFI Live and DSP 5 By MMLMM, RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Titan 52gal fuel tank, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline   Reply With Quote
Old 08-27-2009, 09:10 PM   eBay Motors  #15 (permalink)
Super Moderator
BigRedChevy's Avatar
Originally Posted by RedBowTies88 View Post
i say thow a filter over it and use it as a second intake...whatchu think brian?
Thats not a good idea either. Your maf won't be reading all the air flow and will pull fuel. If you want to see how bad it will get go pull your intake tube off and take a short trip. Not fun.
KYLE
2010 Camaro SS LS3 426 HP
Old 08-27-2009, 09:43 PM   eBay Motors  #16 (permalink)
chevymakesitizuzushakesit's Avatar
cool video
05' CCSB 4x4 DMAX/Allison is junk
# 15 top 25 slowest stock duramax
wooster diesel performance!
chevymakesitizuzushakesit is offline   Reply With Quote
Old 08-28-2009, 06:48 AM   eBay Motors  #17 (permalink)
GWEEDO!!!!
i was just joking about that lol hence the the little guy
CC/SB LLBYE
Old 08-28-2009, 07:03 AM   eBay Motors  #18 (permalink)
timespentsearching's Avatar
to make a LB7 perform betterr and whistle more here are the things to do. first if your running stock intake plug the res. second modded intake horn. third, the 3.5 straight pipe is nice but a 4 or 5 inch will whistle even alittle more. fourth you can get an intake and that does help it whistle alittle more and spool slightly faster. fifth, when i get the new compressor wheel done here in a week or some, add one of those. they will flow aobut 15% more air and spool at 12-1300 with a modded intake horn.
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders, 255/85R16 BFG KM2
Screamin Diesel Performance
timespentsearching is offline   Reply With Quote
Old 08-31-2009, 03:46 PM   eBay Motors  #19 (permalink)
racerx909's Avatar
gotcha...learn something new every day....however i dont think out garretts have such a thing...so it looks like were back to brians idea
BTW lb7 uses an IHI, not a garrett
03 2500 ECLB LT Pro Comp, 285's, Edge CTS, PPE Boost Valve, Stock Straight Pipe
racerx909 is offline   Reply With Quote
