LLY turbo upgrade - Chevy and GMC Duramax Diesel Forum
Turbo's Stock and Aftermarket. Place for all your turbo questions
post #1 of 23 (permalink) Old 01-20-2011, 04:44 PM Thread Starter
Farmer93's Avatar
LLY turbo upgrade
I am wanting to upgrade my stock turbo but I am not sure what to go with. I though about a garret drop in replacement. or an auroa 3000 or 4000 I dont tow a alot but when I do I want somethin reliable. Also I amm hopin to get around 600 rwhp. What is my best option.
04LLY. K&N Intake- EFI Live 5 position by IdahoRob-Sinister Diesel EGR Delete- PPE stage V tranny- Triple Disk Converter- MBRP 5 inch Stainless to an MBRP Monster 8 inch tip- resonator plugged- 3 inch intercooler pipes- Profab y-bridge- S&B mouthpiece-FASS 150gph- Autometer Sport Comp 2 Pyro and Boost guages- Cognito leveling kit and UCA's- PPE Tie Rod Sleeves- Empire Diesel Center Link- Rough Country Add-a-Leaf- Bilstein 5100's Front and Rear- homemade traction bars-Mickey Thompson ATZ 285/75/R16
Farmer93 is offline
post #2 of 23 (permalink) Old 01-20-2011, 04:45 PM
saw what you did there
theunderlord's Avatar
are you set on a single?
MY11 Volkswagen Golf TDI 6MT.
6K Lows, 3K Fogs, Tint.
CLICK BEFORE YOU POST!
theunderlord is offline
post #3 of 23 (permalink) Old 01-20-2011, 04:47 PM
give danville performance a call(317) 745-2428 its capable of 600rwhp with supporting mods
2005 white cclb 4x4 leveled 20"bmf novakanes with 305/55/20 nitto terra grapplers, danville 2.6 68mm stage 2 turbo, danville modded lbz cp3, danville 60% injectors, lbz mp,all season egr delete,pcv reroute, efi live,ppe fuel fittings race valve fass150 hd lift pump banks techni cooler with ic tubes ppe manifolds and up pipes grizzly locker danville tierods sleeves cognito braces and super steer danville traction bars and suspension stops suncoast gmax5 trans with billet input and output shafts and 1056 tc danville t case pump upgrade merchant t case brace edge insight S&B intake and 5"mbrp exhaust,amp research power steps efi live v2 TUNED BY MARK BROVIAK 650 rwhp 1200 torque
swifty is offline
post #4 of 23 (permalink) Old 01-20-2011, 04:48 PM
what is, their phone number?
post #5 of 23 (permalink) Old 01-20-2011, 04:50 PM
duramaxxin73's Avatar
What are your plans for the truck? Are you going to do some sled pulling and drag racing. Or just want to have fun on the street. Are you thinking that maybe later on you might want to go with twins? We have some good turbo options. If you have any questions then I would be more than glad to answer them for you.
2004.5 Chevy Silverado (J.T.) 2500HD "Dirt Nasty" LLY
Currently under construction for ODL
EFI Live Tuned By Mark Broviak @ Danville Performance
Danville Performance Specializing in GM Performance including Duramax Diesels from stock to Full out competition trucks. Custom EFILive tuning, In house Dynojet 224LC Dyno, Custom Danville Performance Turbos including VGT's, Modded LBZ CP3's, Sled pulling setup and parts, competition built motors, etc... For more details Call Larry, Matt, or Mark at 317-745-8587
www.DanvillePerformance.com
duramaxxin73 is offline
post #6 of 23 (permalink) Old 01-20-2011, 06:41 PM
MarkBroviak's Avatar
For your LLy you would want my 2.6 Stg2 turbo. It will get you the power that you are looking for without the expensive of an aftermarket kit and is a drop in replacement turbo. There is no waiting for it to spool up as it is faster than stock. With enough fuel it will do 650hp and has gone 11.93@111mph. It is a great choice for your stock motor.
06 LBZ RCLB 2wd "White Lightning" drag truck1,151RWHP-2,020+rwtq 1.58 60ft 6.92@103mph 1/8th 10.96@127+mph as is!
SC 1056 GMax6, DP Billet72mm/TCTBMW366 HSP Triples, 12mm Exergy Stroker CP3&200%inj, PPE RV& Highflow cp3 fitting,PPE Manifolds, Fass, AllSeasonHighflow EGR Delete& Manual lockup, Grizzly w/3.42's
Specializing in Duramaxs from stock to Full Race!
Custom Danville Performance Turbos including VGT's, Modded LBZ CP3's, Sled pulling setup and parts, etc...
www.DanvillePerformance.com www.youtube.com/markbroviakdp
MarkBroviak is offline
post #7 of 23 (permalink) Old 01-20-2011, 06:41 PM
blaineGMC's Avatar
Twinz
blaineGMC is offline
post #8 of 23 (permalink) Old 01-20-2011, 07:24 PM
thanks for taking over Mark I miss daily driving a stg2
post #9 of 23 (permalink) Old 01-22-2011, 07:10 AM Thread Starter
Farmer93's Avatar
I am wantin to do some sled pullin but mostly streeet fun and towing
Farmer93 is offline
post #10 of 23 (permalink) Old 01-23-2011, 02:31 PM
the stage 2 would be a good set up for you then. Thats what I ran when my puller was still my daily driver/weekend sled puller, and I had very good results with it.
