05 lly turbo locked up will early 06 turbo swap out - Chevy and GMC Duramax Diesel Forum
Turbo's Stock and Aftermarket. Place for all your turbo questions
post #1 of 7 (permalink) Old 04-21-2011, 11:59 AM Thread Starter
I have an 05 that the turbo seized up on. I also have an early 06 prod date 8/05 that is totaled will the 06 turbo fit the 05 and what is involved with the swap. Thanks for any help
.2005 dmax stock. ppe maximizer,hypertec programmer,fuel shim, deleted muffler and cat 176,000 miles .
marty cormier is offline
post #2 of 7 (permalink) Old 04-21-2011, 12:00 PM
Quicker Then Brian!
RedBowTies88's Avatar
yep its a drop in replacement
Beech - 05 LLY CC/SB 4x4
12.31@108.57 On stock turbo and fuel system
Thanks to,
Big Dipper, Efilive, Calvert, Precession Converters, Nick@Duramaxtuner, Eaton, Pureflow, and Falken
RedBowTies88 is offline
post #3 of 7 (permalink) Old 04-21-2011, 12:08 PM Thread Starter
Called some salvage yards and they said interchange numbers were different
post #4 of 7 (permalink) Old 04-21-2011, 12:10 PM
Quicker Then Brian!
the turbo's are not identical, the lly is slightly larger however its still a direct replacement
Thanks to,
post #5 of 7 (permalink) Old 04-21-2011, 12:17 PM
maxthis's Avatar
Send a message via Yahoo to maxthis
It's kind of a pain in the ass but i have mine almost completely apart after working on it for about 2.5 hours. About ten minutes more tonight after work and i will have my stocker out.
It's not very hard work at all, biggest pain in the ass is moving stuff out of they way to get to your turbo.
-remove downpipe heat shield, turbo heat shield, remove intake and turbo mouthpiece, i also removed my pcv plumbing
-drivers side intercooler pipe, remove intake bridge, drain a couple gallons of anti-freeze
-remove glow plug contoller, un bolt a/c compressor and lay it on the passenger side battery, a couple wiring harness, remove vain positioning sensor....
Then its time for the good stuff...
-remove down pipe, un-bolt up pipes(pain in the ass, but not bad)
-unbolt oil drain, unbolt water lines, un-bolt oil feed, unbolt the 3 turbo pedistal bolts....that's all thats to it!! Lol
04.5 LLY
-68mm Cheetah w/ 4" dp
-DSP5 and G-Max5/1058 by Fleece Performance (473/871)stock turbo
-Leveling kit, 33" ATZ's 18" Ultra Predators
-shim kit, egr and resonator blocked
-Cognito Braces, PPE tie rod sleeves,60" traction bars
-4" banks turbo back and 5" MBRP miter cut stack
-AFE mouthpiece, K&N Stainless intake, AirDog 150
-Cowl hood, spray in bed liner
maxthis is offline
post #6 of 7 (permalink) Old 04-21-2011, 12:18 PM Thread Starter
Thanks man was seating this thought the spare would not fit and I would have to buy a nother
post #7 of 7 (permalink) Old 04-21-2011, 05:30 PM Thread Starter
Remembered a few things prior to failure I noticed the temp was a lil higher than normal and oil pressure was lower than normal could this have caused turbo failure or is it cause seals were blown
