Looking to upgrade BIGGER - Chevy and GMC Duramax Diesel Forum
Turbo's Stock and Aftermarket. Place for all your turbo questions
post #1 of 27 (permalink) Old 04-30-2011, 10:19 AM Thread Starter
With the stock turbo, I boost only to about 18 psi. Whats a better upgrade to produce more boost to make more HP & torque. Yes, I have a stock trans, rearend only have the Banks 6-gun full package. Will any of the newer turbo's bolt up as a replacement?
2002 Chevy Crewcab Duramax 2500HD
Strick 9 is offline
post #2 of 27 (permalink) Old 04-30-2011, 10:21 AM
ahduramax's Avatar
get the PPE boost valve
2007 CCSB LBZ
ahduramax is offline
post #3 of 27 (permalink) Old 04-30-2011, 11:13 AM
GeneralTJI's Avatar
Boost valve and tuning. Stock turbo has enough power to run 12's no prob. You will destroy the trans long before that obviously. But you have enough turbo to make pretty good power.
(The boost valve will hold the wastegate closed until you reach higher boost)
06 LBZ / 6spd Allison 4x4 ec/sb
Self built/tuned sideways s366 setup | DPC converter / Co-Pilot | 1792 / BD Filter| Black 5" Hood Stack | Homebuilt Trac Bars | Coil-overs | 250psi water/meth | Black MM951's | roll pan | Autometer/ISSpro/UltraGauge | sleeves | self Lowered | deep pan etc.
12.61 @ 105 - 5800ft elev (stock trans) 12.6 vid
Parted out my car for a Pilot's License!!!
GravityKnightFlying
GeneralTJI is offline
post #4 of 27 (permalink) Old 04-30-2011, 01:05 PM
WishforaDMax's Avatar
Ur problem is the banks, what the others said is correct, ditch the banks get efi live a lift pump and build the tranny then see if u still want to upgrade the turbo. U haven't even maxed out it's potential no reason to upgrade it
Names Yezin im 24 and yes i bought my truck myself
2006 CCSB 2500Hd Lt2 LLY DMax, Efi live 150hp Idaho Rob , 5in Straight Pipe 6in Black Tip:rockin, Diamond Eye Dp, Tie rod sleeves, Edge Insight cts, SDP Egr Delete Pipe, Fprv shimmed, Pcv Reroute, All On mod, Blue led's in gauges cluster, Clarion Nx700, 8000k HID's highs/lows/fogs, Rbp Locking Fuel Door, Recons with Led Reverse lights
Name is Sharks06LLY on Duramaxdiesels.com
WishforaDMax is offline
post #5 of 27 (permalink) Old 04-30-2011, 01:12 PM
jeffro.tull's Avatar
the PPE boost valve is a good investment and the price is right at about 30 bucks. IT should be good for an extra 2-5lbs of boost, and really easy install.
06 GMC LBZ CCSB SLT 4x4
rerouted, plugged, leveled, debadged, 4" turbo back, NBS cab lights, 17x9 XD Hoss on 285 cooperATP, sony touchscreen, BU cam, insight
Sold:
03 GMC LB7 ECSB SLT 4x4
jeffro.tull is offline
post #6 of 27 (permalink) Old 04-30-2011, 01:17 PM
jessman388's Avatar
Im seeing 26-28 PSI pretty easily with a stock turbo, BIV, and a QSII on 90 HP. I would try different tuning man, and get a BIV to go with it.
2002 CCSB 4x4 LT. Dark charcoal exterior/black leather interior. 20x9 Death Metal Novakanes. 33 12.50 20 MT's. NBS smoked cab lights. Double Din in dash. 5" exhaust. Downpipe. AirDog II 165. Home made 4" intake. Home made traction bars. KrYpTiK Tuned.
jessman388 is offline
post #7 of 27 (permalink) Old 04-30-2011, 01:23 PM
Banned
You have a long way to go untill you need a bigger turbo.
And remember, a bigger turbo is a power supporter, not a power adder
Hondarider552 is offline
post #8 of 27 (permalink) Old 05-01-2011, 11:24 AM Thread Starter
I should add the list of things I'v done to it 1st, I'v already done the ppe Boost valve, the little Blue inline valve.
I thought once you put a package (Banks 6-gun w/speed loader) thats a tune. Am I wrong?
I'm hearing from many other people to get rid of the Banks system, That it's to weak or safe. But all in all I'm only hitting about 18psi max on the turbo w/the PPE boost valve, why? Should I tweak the Banks BIG HEAD waste gate to flow more boost? If I do whats the max Boost the stock turbo can handle before I grenade that tiny thing?
Strick 9 is offline
post #9 of 27 (permalink) Old 05-01-2011, 11:29 AM
jessman388's Avatar
Where is your boost tap located at? Maybe you are getting an inacurate reading. And yes you might have that big head wastegate improperly adjusted and are just losing boost. If you do adjust it I would stay below 30-31 PSI. BTW, with better tuning, that "tiny thing" turbo will break plenty of parts on that truck before you will need a turbo upgrade. Just saying man, its not a bad turbo up to 500HP or so.
post #10 of 27 (permalink) Old 05-01-2011, 11:29 AM
DirtyMaxx03's Avatar
sounds like you have the gate set to 18psi. so try to set it at 28
Sean
2003 Lb7 2wd
Dropped
Efi Live by Rob Coddens
s472
DirtyMaxx03 is offline
