Go Back   Chevy and GMC Duramax Diesel Forum > Specialty Forums > VIN Check
VIN Check VIN request here. You must Have 25 post Before you can post in this Forum.
Old 12-27-2008, 09:32 AM   eBay Motors   #1 (permalink)
poyse2b3's Avatar
VIN Check PLEASE
Vin- 1GCHK23225F903907
email- jonathan.poyser@gmail.com
Thank You!
2005 LLY Grey CC/SB
Performance- PVC Reroute, Resonator delete, 4" Turbo Back, Predator 100hp tune
Looks- 6" Pro Comp Lift, 20" Kruz with 35" Terra Grapplers
Wanted- EFI Live, Suncoast Stage IV, BD Manifold, PPE Race Fuel Valve, FASS 150, Crank It Up Centerlink/Tie Rods, KB TCAI/IOH Kits, EGR Delete, Pyro/Boost Gauges... And More
poyse2b3 is offline   Reply With Quote
Old 12-27-2008, 09:41 AM   eBay Motors   #2 (permalink)
poyse2b3's Avatar
front diff question
i also have a quick question i know you are a chevy tech and i have 2 trucks one is an 05 gmc with a 6" pro comp lift and the other is a stock 05 Chevy both 2500 both dmax, i would like to swap out the suspension components on the two i know that to install a lift you need to cut off the upper bracket on the front differential so my question is can i just swap the full front end like differentials and everything? or would they possibly have different gear ratios so that might not work? thanks for your help -jon
2005 LLY Grey CC/SB
Old 12-28-2008, 09:10 PM   eBay Motors   #3 (permalink)
vin check sent
2005 LT 3500HD CCLB SRW LLY
EFI LIVE TUNED BY IDAHOROB
TCM TUNED BY MMLMM
Lbz intake and mouthpiece
Torsion lift keys
MBRP 4" turbo back
Mcculloch 5300k HIDS
Old 12-28-2008, 09:11 PM   eBay Motors   #4 (permalink)
yes as long as they both have the same gear ratio. Everything else is idential. You need to check if they both have 3.73 or 4.11. If you swap them and they are different. It will go boom right away.
TCM TUNED BY MMLMM
Torsion lift keys
MBRP 4" turbo back
Old 12-28-2008, 09:51 PM   eBay Motors   #5 (permalink)
poyse2b3's Avatar
gear ratios
thanks very much how can i find out what gear ratio each truck has... that is where do i look to find that info. thank you very much again for the vin check -jon
2005 LLY Grey CC/SB
Old 12-29-2008, 12:46 AM   eBay Motors   #6 (permalink)
Look on the sticker on the front top of the case it will tell you.
TCM TUNED BY MMLMM
Torsion lift keys
MBRP 4" turbo back
HTML code is On
