Go Back   Chevy and GMC Duramax Diesel Forum > Classifieds Area > Wanted Items
Wanted Items Looking for something? Post a wanted add here!
Old 04-23-2008, 05:10 PM   eBay Motors   #1 (permalink)
Coyote
Points: 271, Level: 5
Points: 271, Level: 5 Points: 271, Level: 5 Points: 271, Level: 5
Activity: 0%
Coyote's Avatar
CAT from an '06 LBZ
Anyone still have their old downpipe with converter? I wanna try something.
2006 White 2500 HD-Allison-LBZ-CCSB-Leather-Sunroof-XM, Bed over spray in Line-X, Truxedo Lo Pro QT, Debadged (except Alli/Duramax), Prodigy brake controller, Raised 1" in front, USA-SPEC iPod to GM interface, EGR Blocked & Finger Stick, Modded airbox, PCV re-routed.
(www)s140.photobucket.com/albums/r15/coyoteosf
To Do List:
FS 2500 bypass oil filter, 3-4" lift, Full 4" exhaust(minus cat), 18" wheels, Nicktane aux fuel filter, Trans Go Jr, modest programmer, BD’s Full Bore exhaust manifold, gauges.
"If guns are outlawed, how will we shoot the Liberals
Coyote is offline   Reply With Quote
Old 04-23-2008, 05:26 PM   eBay Motors   #2 (permalink)
Johnasara
Points: 1,952, Level: 18
Points: 1,952, Level: 18 Points: 1,952, Level: 18 Points: 1,952, Level: 18
Activity: 52%
Activity: 52% Activity: 52% Activity: 52%
Johnasara's Avatar
I still have the whole exhaust system. Want it???
06 2500 CREW CAB 4X4 LBZ
4" DIAMOND EYE EXHAUST, KITTY RAN OFF!!!
DIABLO @ 85HP. 285/75 BFG's RUNNIN ON ULTRA 16's
PIONEER HEAD UNIT RUNNIN SCOSCHE AMP W MTX TWINS
AIR BOX IMPELLER REMOVED!! RESONATOR PLUGGED !!!
AUTOMETER ULTRALITE GAUGES IN POD
WORK RIG
O7.5 3500 CREW, LMM
ROYAL UTILITY BED
SOME MODS, MOSTLY EXTERIOR
Old 04-23-2008, 07:13 PM   eBay Motors   #3 (permalink)
Landscapeman
John Deere Green
Points: 2,957, Level: 22
Points: 2,957, Level: 22 Points: 2,957, Level: 22 Points: 2,957, Level: 22
Activity: 19%
Activity: 19% Activity: 19% Activity: 19%
Landscapeman's Avatar
X2 have the whole system
2006 GMC 2500HD LBZ Crew Cab 4x4, Silverline Turbo Back Dual Exhaust, PPE Hot Programmer, Egr Block Plate, PPE Air Box Mod, 2in. Plug, SES Light
Full Bore Exhaust Manifold compliments of BD Diesel.
Landscapeman is offline   Reply With Quote
Old 04-23-2008, 09:05 PM   eBay Motors   #4 (permalink)
lubeman1969
Points: 654, Level: 9
Points: 654, Level: 9 Points: 654, Level: 9 Points: 654, Level: 9
Activity: 7%
Activity: 7% Activity: 7% Activity: 7%
If you guys still have your converters- look at your local recyclers- they will pay good money for them. They extract the platinum content. I know this is true -we have sold many and cashed in on money we had laying around!!
2006 2500 LBZ CREW CAB LONG BED
EDGE JUICE W/ ATTITUDE
315'S W/ 17" GEAR LOCKER 714C WHEELS
FABTECH 6" LIFT
BD EXHAUST MANIFOLD
S&B COLD AIR INTAKE
4" STRAIGHT PIPE EXHAUST
1 CARSEAT IN THE BACK!!
lubeman1969 is offline   Reply With Quote
Old 04-23-2008, 10:03 PM   eBay Motors   #5 (permalink)
Coyote
Activity: 0%
Coyote's Avatar
Gee thanks for the back door job there dude. I need just one so I can fool my county emissions tester (SMOG test).
To Do List:
Old 04-23-2008, 10:26 PM   eBay Motors   #6 (permalink)
psyco66
Points: 2,912, Level: 22
Points: 2,912, Level: 22 Points: 2,912, Level: 22 Points: 2,912, Level: 22
Activity: 85%
Activity: 85% Activity: 85% Activity: 85%
psyco66's Avatar
Where are you from. I am keeping my cat incase they start to test trucks in CA and I need to put it back on to past a test then rip it back off.
John
EFI LIVE with McRat tune, DPS5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Suncoast Stage IV built by me.
NO TALKING JUST LINE IT UP
psyco66 is offline   Reply With Quote
Old 04-23-2008, 11:48 PM   eBay Motors   #7 (permalink)
Coyote
Activity: 0%
Coyote's Avatar
I live in Boise. I am going to hollow out the CAT and slide it over the aftermarket exhaust. That way when the SMOG tester uses his "mirror on a stick" to see if there is a CAT, I should past the visual test.
To Do List:
Old 05-16-2008, 05:30 PM   eBay Motors   #8 (permalink)
Radar
Points: 391, Level: 6
Points: 391, Level: 6 Points: 391, Level: 6 Points: 391, Level: 6
Activity: 0%
They are a bitch to hollow out.
Radar is offline   Reply With Quote
Old 05-16-2008, 05:39 PM   eBay Motors   #9 (permalink)
4x4Fantasy
Points: 2,095, Level: 18
Points: 2,095, Level: 18 Points: 2,095, Level: 18 Points: 2,095, Level: 18
Activity: 71%
Activity: 71% Activity: 71% Activity: 71%
4x4Fantasy's Avatar
Yeah good luck on the hollowing out. Back when I was in high school I helped a friend use a steel pipe.....NOT EASY!
4x4Fantasy is offline   Reply With Quote
Old 05-16-2008, 08:53 PM   eBay Motors   #10 (permalink)
mackthehack
Points: 1,773, Level: 17
Points: 1,773, Level: 17 Points: 1,773, Level: 17 Points: 1,773, Level: 17
Activity: 2%
Activity: 2% Activity: 2% Activity: 2%
psyco66, if I can remember correctly when the smog commies start doing diesels it's for everything under 8560 lbs. Our trucks are 9200+ lbs. I've talked to a couple smog techs and that is what they said about weight, so 3/4,1 tons are exempt. But you know how Cali Liberals change their minds all the time.
mackthehack is offline   Reply With Quote
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
