| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | Wheels&Tires Discuss what wheels&tires are right for you.
Sponsored by Discount Tire |  | |
09-23-2008, 12:47 PM
eBay Motors
#1 (permalink)
| | Member
| clear coat on stock wheels Can anyone tell me how to get the clear coat off of my stock wheels. Or is it a good idea? My wheels have lead weights on the outside of the wheel, thanks alot Big O tires. The wheels were this way when i bought the truck but it is increasingly annoying me. Should I take the clear coat off or not. It looks like crap all peeling off around the bead. I hate the way it looks but I also don't want to spend hours polishing aluminum. Any suggestions.
__________________ 05 2500 4x4 EXT CAB SHORT :usa
EDGE JUICE WITH ATTITTUDE
AFE COLD AIR INTAKE
STRAIGHT EXHAUST |
| Advertisement
09-23-2008, 01:57 PM
eBay Motors
#2 (permalink)
| | DF Sponsors
| they have a clear coat on them? alum wheel or steel. as for the lead weights you ahve you have though man, thats how they balance your tires
__________________ Pickup: 03 GMC 2500HD EXT Cab Long Box
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: SDP 64.5mm www.screamindieselperformance.com
Modded IHI and Garrett VVT turbos
Turbo Port and Polish
Turbo Rebuilding |
09-23-2008, 02:08 PM
eBay Motors
#3 (permalink)
| | Senior Member
| Yes but, most wheels they can put the weight's in the inside of the wheel. Either way though I'm not sure your factory wheels have a clear coat!!
__________________ 2004 Chevy 2500hd LB7, 78,000, Allison 5 Speed 6" RCD Suspension,
17" Moto Metal 951"s w/35x12.5R17 Toyo m/t, Magnaflow 4"
Turbo back, Cognito Heavy Duty Sway Bar End Links, Gm Power Steering Cooler,
other than that all stock.......FOR NOW!!!!!
What lies behind us and what lies before us, are small
matters, compared to what lies within us!!! |
09-23-2008, 02:32 PM
eBay Motors
#4 (permalink)
| | Duramax Lifetime Supporter
| I always make sure to tell them no hammer on weights! I did and one time at Les Schwabs, who I use all the time, they still put the hammer ones on so I made 'em rebalance and use the stick on weights on the inside of the wheels.
__________________ Stan
2005 Chevy Silverado 4x4, 285-70-17's on Hummer wheels. 24,000 miles. Banks Ram Air inlet system. Predator programmer, KillerBee modified mouth piece.
93 Dodge D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust,modified tranny,EGT/boost/tranny/tach gauges.Rear sway bar.Single stage Water/Meth system installed. Oversized intercooler |
09-23-2008, 03:46 PM
eBay Motors
#5 (permalink)
| | Duramax Forum Moderator
| The stock aluminum wheels do have clear coat on them. Mine is peeling like crazy and I'm just about ready to take it all off and paint them black. Someone on here said that MEK will take it off. Can't remember what MEK stands for but I saw it at lowes for 8 bucks. Will that take it off?
__________________ Brian
PPE Standard level 2
Kodiak mouthpiece
Truxedo Duece Tonneau
06 style leveled towing mirrors, 285 75 R16 BFG AT KO
T Bars cranked all the way (bad) BUY FROM MPF!!!!! |
09-23-2008, 03:51 PM
eBay Motors
#6 (permalink)
| | DF Sponsors
| Quote:
Originally Posted by DuramaxOnTheBrain The stock aluminum wheels do have clear coat on them. Mine is peeling like crazy and I'm just about ready to take it all off and paint them black. Someone on here said that MEK will take it off. Can't remember what MEK stands for but I saw it at lowes for 8 bucks. Will that take it off? | dont paint them, have them powder coated
Airtake: S&B intake
Fueling: Airdog 150
Turbo Rebuilding |
09-23-2008, 04:02 PM
eBay Motors
#7 (permalink)
| Quote:
Originally Posted by timespentsearching dont paint them, have them powder coated | I'd love to but I don't want to put any money in them. If I'm gonna spend any money I'll get after market ones.
Kodiak mouthpiece
09-23-2008, 08:45 PM
eBay Motors
#8 (permalink)
| | Oh.... Squirrel!!
| Ya they have clear coat on them. Id say your best option is to get them sandblasted or bead blasted. Then have then proffesionally cleared with automotive paint. Not spray bombs.
Also, there is a big difference in ballancing a tire with weights on the inside and outside... Its not just for "looks" If you care about the ride then in and out are better. That balances a wheel for it going side to side. Inside weights fix a wheel or tires thats out of round or egg shaped.
__________________ Jason 2006 Silverado 2500HD LBZ CC SB Escalade Handles, Front windows tinted to match the rear, painted bumpers, billet grille 4 Kicker 10in Subs in 2 custom box's, Autometer Ultra lite II Pyro and Boost gauges HID Highs, Lows, Fogs Transgo Jr, Cognito Braces, MBRP Turbo Back Stainless Exhaust (Straight piped), w/ stainless tip PPE Hot+2 285/70/17 Nitto Terra Grapplers on Pro Comp Wheels ****Lost Kitty Reward if found!!**** 1999 Ford F-550 PowerStroke ''Wrecker'' **Jerrdan bed, S&B Intake |
09-24-2008, 11:50 AM
eBay Motors
#9 (permalink)
| | Member
| Can anyone give me a guestimate on what blasting and powder coating or clear coating would run. Never priced anything like that before.
AFE COLD AIR INTAKE
STRAIGHT EXHAUST |
09-24-2008, 08:43 PM
eBay Motors
#10 (permalink)
| | Oh.... Squirrel!!
| Hmmm It depends. It will be hardest to find someone to blast it and really wont cost much to clear them. Powder coating would coat more than clear would. You'd have to just call around and get the best prices! Id call body shops who might sand blast and clear coat!
