Guys,
Have an 08 CC dually. The new 08's come with really small tires on 17" wheels. I am told that the only size larger tire that I can put on it is a 235/80/17.
Can anyone give me any advice on whether or not this is true and if so, what would be the best AT tire I could put on it.
I have goodyear wrangler A/T and they are 30.5" on my stock rims without a problem or rubbing.
__________________ 2001 2500HD LT CCSB 4X4 LB7 TAPE DECK INCLUDED
Leather, Power everything, Autometer Cobalt Boost and Pyro, HID headlights/fogs, 05' Tailights, De-Badged, two JL audio 12" subs, Four Rockford Fosgate three way speakers
35" Wrangler DuraTracs on KMC 20" Rockstars and a 6" procomp drop knuckle and black Westin runners. EFILive tuned with DSP5 for Extra Go-Go Modded intake horn, Banks Big Head wastegate, banks ram-air intake, banks straight pipe
Other TOYS:2005 YAMAHA YZ250F Rat Racing motor Enzo Racing Suspension: Forks and shock, Chad Reed's actual front fender.
Wish List: Suncoast iv, AD Lift pump, Timespentsearching's compressor upgrade.
Well I work at a farm tire place so I would say 235/80-17 should fit ok. You might be able to 245 if you are lucky. And tires are really up to what you wanna do with them. Do you want an AT that is quiet on the road and good traction or loud on the road and great traction or somewhere in the middle? I do like my BFG All Terrains but they are a little loud
Yeah. Well the Wranglers are a pretty good tire. So are the Firestone Destinations AT's are pretty good too, but i don't think they make a 235/80-17 either. Its kinda an odd size
You can go plenty bigger. They make a spacer that goes between the tires. Lots of guys on here use it so they can put bigger tires on without rubbing. I think there's some guys here runnin like 265's or somewhere round there
if your looking for milage go with the 235. i run 235 on my pickup, better milage, better traction towing in rain and snow, ride nice. i have 235/85/r16's though but really will be the came size weight wise. if your going to be in the mud at all though go for osmething wider, a 265 or 255
__________________ Pickup: 03 GMC 2500HD EXT Cab Long Box
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
They do make 245/75-17 BFG's so if you don't wanna go alot bigger there you go. And I think the rule for duals is 2 inches between them at the bottom? I might be wrong
I wouldn't own the Goodyear Wrangler's again if they gave them to me. I had them on my old truck, rotated them every 5.000 miles and only got 20k out of them. I have very inexpensive Wild Country's now, and I've got almost 20k on them already. They don't look brand new, but more than half of the tread is left. In my opinion, Goodyear's are over-rated and over-priced. For a thousand dollars, I expected a lot more out of mine. Also had the BFG's, and they didn't last either. Only about 30k on those. Never hauled much on the BFG's, so that's not what wore them. It has been my experience that the less expensive tire, the better.
__________________ '07 Classic 2500HD ext. cab
nerf bars
delta diamond plate tool box
back rack
Edge Juice w/attitude
K&N CAI
MBRP 4" turbo back w/5" tip
Moto Metal 16 x 9 (hopefully 285's soon!)
Thats crazy cause i have had mine for 35K and they are almost worn, i got one more rotation on them at least.
