load range d should be way more than enough, I have load range c on truck and tow a 5th wheel with a 1550 pin weight and have no problems; good luck and let me know if you need some prices
__________________ 04.5 LLY Crew Cab, Quadzilla Stealth 2, K&N Intake
EGR Block Off Plate, TEMPRA Revenger R/T'S 285's
Autometer Boost & Pyrometer Gauge
4 in. MBRP Exhaust Turbo Back
PCV Valve reroute
4 in Nasta Stainless Steel Tube Steps
AVS Window Vents, Deer Whistles
Firestone Ride Rite Air Bags w/ Compressor, Robin Fifth Wheel
rockin
__________________ 2004 LB7 Crew Cab 4x4 SLT
Dyno stock numbers 454.3rwTrq and 246.8rwhp boost 22psi EGT 1100 23.2mpg @70mph hwyAmsoil-Air Filter, motor oil, both Diff's, Tranny, Tranfer Case Autometer C2 0-35boost and 0-1600temp gauge Cooper STT Tires 285/75-R16 PPE Standend set on 40hp/160trq and Boost valve Single Flowmaster 4" with a SS 5" tip, two Interstate battery 800 CCA
I have two buddies that had the coopers M/T's and they both said they were the worst tires they have had. They seem to have short tread life and are loud. They also are about as expensive as the Toyo M/T's and BFG M/T's. If I were you I would check out those first before buying. I have Toyo's and love them. Good Luck!
__________________ 2002 Dmax
8" BDS lift 35's on 20's
AMP power steps
Edge juice w/ attitude
5" turbo back straight pipe
AFE intake
i hate to say this but DO NOT go under a LR D with a DIESEL equipped truck,you do not have enough tire strenght for that heavy of a truck with a LR C..most 285's come in LR D only but in a 265 i wouldn't run anything under a LR E if you tow but if the truck runs empty for the most part and tows 5,000-6,000LBS at best the LR D's will work but not recommended..
the older Cooper MT's aren't a very good tire but the new STT has been a great tire for most people and has rated realy high in most online ratings..
__________________ James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
I always stick up for my Bridgestones so here goes: Got 265 Bridgestone revo's. Been great for me. I've got 40k out of them, with some pretty hard abuse, towing, and lots of gravel road time, and in town driving, along with the highway miles. I should get about another 10k out of them before I buy another set. The main reason I like them is for their winter handling. They are AWESOME in snow!! I can push snow with the bumper in 2wd. Thats the main reason I got em. So I can haul a truckload of goose decoys, blinds, buddys and dog out into a muddy snowy field and not have to worry bout getting stuck. They also do great in rain, I've NEVER had a problem hydroplaining. They've worn pretty good too considering how loose my front end is!! And they're still just as quiet now after 40k as they were new. I don't play in the mud much anymore, but they've never let me down when I've needed to go through some serious muck. Now their not a MT they're AT, but they do ok in mud too. And they look pretty bad ass I think. And they have the white lettering which I like too.
I had a set on a lifted grand cherokee i had. deff a m/t. they wore good, considering the abuse i put them through and were pretty quiet for as aggressive as they were. i would recommend them.good prices too!
__________________ 2002 Chevy 2500HD Extended cab, SB
5" exhaust into a 6" stack.
Autometer Cobalt Boost and Pyro Gauges Thanks MPF!
PPE Hot+2 level 3
Drawtite gooseneck
20's
Panasonic deck
custom mounted Sirius radio w/ lifetime subscription. http://performancetruckproducts.com/check them out
