Here is what a stock GM UCA and factory frame stop should look like.
* This space will very on every truck that comes off the show room floor because GM sets there trucks up alittle deferent per what tire package they put on the truck.
After you crank your bars up you start to loose rebound/drop out travel.
When you turn your keys up you limit the travel first with your factory shock. Easy fix with extenders or longer shocks.
After the shock you loose drop out travel between the UCA and frame stop. A bad ride at that point, metal to metal. You also get a bad factory ball joint angle that binds and will wear out fast. Also the factory UCA does not allow for correct alignment spec. most of the time.
Turning your bars up are the number 1 upgrade GM owners do to get a little bigger tire under there trucks. So Cognito looked at the problems that occur and came up with there Cognito 2-3 leveling UCA kit. The bases is to correct ball joint angle and alignment specs. When testing there set up they found that the factory CV shafts will allow for alittle more drop out than factory allows. So when you find that the stance you get after cranking your bars is where you want your truck to sit and your ride has gone bad then you have ran out of drop out travel, the Cognito UCA will give you 2" more drop out from there to gain your ride back.
Again does the Cognito UCA kit give you lift? No, it corrects the problems that occur when you level your truck with factory UCA.
- For guys that are drag racing using 4wd and sled pullers, this kit is not for you because the CV angles are greater than you can use at that torq. when in 4wd. A 4" lift with a drop front diff. will work better since you will have level CV angles not cranked up.
- Guys that are every day drivers and regular 4wd offroading, this kit is great for you to get bigger tires under the truck for a better look.
- This kit works best with Bil5100's front and back.
- You can add a rear 1" block and u-bolt to raise the rear as well.
Hope this helps....
Nor-Cal Nick
