Sponsored by Discount Tire
Old 10-19-2008, 12:04 PM   eBay Motors   #21 (permalink)
timespentsearching
timespentsearching's Avatar
Originally Posted by LNXGUY View Post
As long as the overall wheel/tire diameter doesn't change from stock, you won't have to re-calibrate anything, regardless how wide the tire is....
You could run a 245/75-16 and a 305/75-16 and as long as the diameter is the same, you are good to go.
Rolling resistance is also higher with a wider tire, so you'll lose fuel economy, not gain it.... Simple physics.
305 is a taller tirer then 265.
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
Old 10-19-2008, 12:44 PM   eBay Motors   #22 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
yes the 285's will hurt your fuel economy but for most only around 1MPG but if you want the best look the 285's are the ones you want..
the wider the tire the more rolling resistance which will knock fuel economy down even though they are the same height as the 245-75R16's,if you want the same height as the 285's with less width the 255-85R16 works great although it is kinda hard to find anymore..
when it's all said and done the 265's will save you fuel money and the 285's will give you the truck look.
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 10-19-2008, 01:28 PM   eBay Motors   #23 (permalink)
Duramaximos
Duramaximos's Avatar
My personal favorite size is 265/70R18.
Yes it will require a new set of wheels but I believe this size offers the best look without compromising performance or fuel economy too much - in my opinion.
It will have less mass and rolling resistance than a 285, but it is still 2" taller than stock 245/75R16.
I'm beginning to believe most 285's won't fit due to incorrect off-set and excessive width, rather than height.
I have fit 265/70R18's under my truck without any trimming or lifting. +25 to 0 offset is most ideal. I'd bet the 265/70R19 would also fit without modifications. These fill out the wheel well nicely without being too wide.
My experience is with the classic B.S. so I'm not certain how this would translate to the NBS.
Good luck
Pictures: http://www.duramaxforum.com/forum/wh...look-sexy.html
2007 LBZ 2500HD CC SB 4x4
Leer canopy, Aries Oval step bars, 18" AR Cannons wrapped with General Grabber HTS 275/65R18's, Bushwacker Pocket Flares, and 2" drop shackles in the rear
Love this truck....HATE the fuel economy yea yea, I know it's a truck, and YES I want the same mpg as a Civic
Duramaximos is offline   Reply With Quote
Old 10-19-2008, 02:40 PM   eBay Motors   #24 (permalink)
Court
Court's Avatar
285's on 18x9's will rub on the new body style trucks. Its not bad, but its enough to be annoying, I learned this from experience. I ended up having to do a little trimming and modifications to my inner fenderwells.
2008 Chevy 2500 Crew Cab Z71 dark Blue Metalic.
Chrome bug shield
Pro Comp 6047's 18x9
BFG's 285/65/18
Lund seal and peel tonau cover
Ready Lift Leveling kit
Front windows tinted to match the rear's
Banks Ram Air Intake
N-fab Nerf Bars (Crome) wheel to wheel
Court is offline   Reply With Quote
Old 10-20-2008, 11:05 AM   eBay Motors   #25 (permalink)
LNXGUY
A 305 is wider then a 265, that number doesn't indicate sidewall height at all.
Sidewall height is the second number in the equation...
Theoretically, a 305/75-16 tire on a 16inch rim should be the exact same diameter as a 265/75-16 on a 16inch rim.
I'm just arguing semantics, but you see where I am going with this?
And yeah, you'll burn more fuel trying to push/pull a 305 series tire down the road compared to the skinny 245 stockers To bad good looks and rotational mass usually go together.
LNXGUY is offline   Reply With Quote
Old 10-20-2008, 11:18 AM   eBay Motors   #26 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Close, but not quite on track. Yes, the 305 is representative of width in millimeters while the 75 represents the aspect ratio to the width, in this case the height is 75% of the width, which would be 229mm tall. At the same time, the 265 with the same aspect ratio would only be 199mm in height. Therefore, thinking the height remains the same between the two tire sizes because some of the numbers are the same would be incorrect. Hope this helps.
Old 10-20-2008, 11:19 AM   eBay Motors   #27 (permalink)
Darryl89
One thing you aren't taking into account here is that the second set of numbers (the 75 in your instance), indicates the height yes, but it is in a percentage. So if a tire is wider, then the percentage result is higher also..ie:
285/75R-16 is 285mm wide with a sidewall height that is 75% as tall as the width is, so on this tire the sidewall height is 213.75mm tall.
On a 305/75-16 tire, the sidewall height it 228.75mm tall. So yes, the wider tire is taller also...
2008 CrewCab 4X4 Z71 LMM LT2, Leveled+1, 285/75R16 BFG TA-KOs on 16X8 Eagle Classics, Bushwacker and N-Fab Goodies, B&W Turnover Ball
Darryl89 is offline   Reply With Quote
Old 10-20-2008, 11:27 AM   eBay Motors   #28 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
So, as an example...
305/65R-16 (198.25mm)
265/75R-16 (198.75mm)
235/85R-16 (199.75mm)
are relatively all the same in overall height while having different fuel/power robbing widths.
Old 10-20-2008, 11:29 AM   eBay Motors   #29 (permalink)
Darryl89
Bingo...yep...
Old 10-20-2008, 06:12 PM   eBay Motors   #30 (permalink)
LNXGUY
Well guys, I gotta say thanks for the education I had no idea the width and the sidewall height were in direction relation to each other. Shows how much I know
Totally offtopic, we just swapped the 285 Toyo M/T's on my dads truck for the winters. We've already seen a increase in MPG's... The Toyo's look awesome, but man do they ever eat into the mileage... We are thinking about 265 BFG A/T's for the next set, any other I should also look at?
