Originally Posted by collecting the remains no no, your right. with the amount of off roading i actually do i have to make the right decision and go with the A/T's. i was also looking at a real nice jeep locally with 35's on it. baja claws. i was thinking if i bought it i should change it to A/T's also. | no one is wrong its all in how you look at it. i run down the road alot loaded. i also go to camp ALOT (<<see avatar<<) so i run the stockers till there bald, then upgrade to the toyo M/T's. they usually lasted about 25 to 30000mi a set on the Ford 6.Slow i used to have.
what you should really do is put A/T's on the Dmax, buy a trailer, buy the jeep, run a key down the side of it and tell yourself its ruined now so i might as well beat on it! then use said trailer and good A/T tires to haul jeep with Baja Claws (best tire for real world off roading) to trial head and proceed to beat it until you have to drag it back on the trailer and tow it home!
__________________ Vehicle 2008 Chevy Crew Cab Short Bed Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck Drivetrain LMM Duramax, Allsion 1000 Transmssion Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo |
