Sponsored by Discount Tire
Old 10-18-2008, 07:41 PM   eBay Motors   #11 (permalink)
LBz074x4
LBz074x4's Avatar
i run BF AT all the way around i run 60 so its smooth without a load and still has enough air to hold a load
Model:2500hd LBZ 4x4
Year: 2007
After market: muffler delete, afe stage II, lone star front bumper
LBz074x4 is offline   Reply With Quote
Old 10-18-2008, 09:59 PM   eBay Motors   #12 (permalink)
Tow Master
ROTM Admin
Tow Master's Avatar
Actually it also depends on the tire size as well. If you have stock wheels and 285 the tires will naturally want to cup and wear fast so you want to put a little less in. I have 285's on 8 inch wide wheels (compared to stock 6.5) so I run a little low to get better wear. If you run stock 245's it might help to run max psi for the tire as well. If you change the tire alot of times the door tire and the on the tire tire pressure will change. Lower pressure will also help the ride alot.
Jason
Old 10-19-2008, 08:24 AM   eBay Motors   #13 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
the reason i run lower PSI is to increase tire wear...
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 10-19-2008, 08:49 AM   eBay Motors   #14 (permalink)
AU Alum
AU Alum's Avatar
I run the factory recommended....can't stand getting the warning on the DIC
White 2007.5 2500HD LT Quad Cab SB, LMM, Automatic, 4x4
Modifications by NOR CAL TRUCK: Cognito 4" Suspension Lift, Cognito Heavy Duty Tie Rods, Bilsteins all the way around, Sulastic Rubber Springs, 52 Gallon Titan Tank, Black XD Revolvers 18x9, 325/60/18 Nitto Terra Grapplers, Autometer Pillar with Phantom Boost and Pyro, Transgo Jr. with Mag Htyec deep pan, EGR Block Plate, BD Exhaust Manifold, Air Lift Air Bags with WirelessAIR, and Nicktane Filter Kit
EFI Live tuned by Idaho Rob
Other Mods: 4" MBRP Exhaust
AU Alum is offline   Reply With Quote
Old 10-19-2008, 09:16 AM   eBay Motors   #15 (permalink)
timespentsearching
timespentsearching's Avatar
increase tires wear? could you try to decrease tire wear so they last longer?
Tuner: EFI Live, DSP5 switch
Airtake: S&B intake
Fueling: Airdog 150
Turbo: DDP 64mm
Suspension: Firestone Air Bags, add a leaf, tie rod sleeves, shock extenders
timespentsearching is offline   Reply With Quote
Old 10-19-2008, 12:34 PM   eBay Motors   #16 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
thats what i get for staying out untill 3 AM last night,i'm not realy working at full power if you know what i mean thanks for correcting that for me.
from my experience with tires if you run the higher PSI in the tires you do increase fuel economy but not enough to compensate for extra tire wear and since tires are fairly pricey anymore along with gas you have to decide which fate you have to take,better fuel economy or better tire wear.the phrase between $h!t and high water comes to mind.sorry if this sounds corny
disclaimer:i'm runing on 3hrs of sleep..
James
Business Truck
DD/Beat Around
Economy Saver
Old 10-19-2008, 01:49 PM   eBay Motors   #17 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Nouse, You’re not going to find a constant here for pressure to run, there’s just too many variables between stock tire size, oversized, brands, Ds or Es and all of this in relation to how much weight is being hauled.
Finding that sweet spot of the optimal footprint is the key, in relation to your setup. My GM sticker on recommended levels for the stock ‘E’ size is 65psi for front and rear. However, I run 70 on the front instead to give the sidewall response I want in quick sudden changes during evasive maneuvers.
With the dual rears and no load on, 65 is just too much with an undesirable sway during sudden changes as there is just not enough contact with the road, 50-55 is much better. However, with 5k lbs of pin weight 65+ is required.
Old 10-19-2008, 04:03 PM   eBay Motors   #18 (permalink)
adamsdmax
adamsdmax's Avatar
i allways check my tires when i rotate them and see how the tread is wearing. if they are wearing more on the middle i will take a few pounds out, if they are wearing on the outside i will add more. This works for me since i dont haul much weight or tow on a daily basis.
04 LLY Silverado 2500HD Crewcab
AEM Bruteforce intake with LBZ mouthpiece
ATS Dual exhaust w/ 6 inch tips
EGR Blocker and Fingerstick
PCV catch can
16" weld racing wheels, 285 BFGs
adamsdmax is offline   Reply With Quote
Old 10-19-2008, 08:28 PM   eBay Motors   #19 (permalink)
dwolbeck
I've got 35" Toyo open country's and they have about 55 psi front and 65 psi back. Should they be lower since they are mud tires and I don't haul much weight?
2008 Duramax
- 6" Tuff Country Lift
- 18" Diamo Rims
- 35" Toyo Open Country M/T
- Billet Grill
dwolbeck is offline   Reply With Quote
Old 10-20-2008, 07:31 PM   eBay Motors   #20 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
with the 35's i would drop down to 55-60 fronts and even as low as 45 in the rears for better tire mileage.
James
Business Truck
DD/Beat Around
Economy Saver
