305/55/20 not 33s??? - Chevy and GMC Duramax Diesel Forum
Sponsored by:
post #1 of 11 (permalink) Old 12-10-2011, 05:06 PM Thread Starter
I just measured my wheel and it measures 32. They terra grapplers.... I thought 305/55/20 was a 33 inch tire? Can anyone confirm? And tell me what is a 33 inch tire that wil fit my 20x9 wheel
Landito86 is offline
post #2 of 11 (permalink) Old 12-10-2011, 05:18 PM
yes they do it all the time
LLY dsp5 ad165
Duramax. is offline
post #3 of 11 (permalink) Old 12-10-2011, 05:25 PM
mackyoudip's Avatar
305 is the width in mm
50 is the % of that mm on each side (sidewall height)
So 50% of 305 mm is 152.5 mm on each side which is 6" each side (25.4mm=1")
so 6"x2=12" add in the rim height (20") an bam 32"
32.007874" to be exact.
Mack: 2004 lb7
1960 f100 Cummapart conversion
Ex's:2006 LBZ ppe tuned
2007.5 LMM s366. 12.4@109
mackyoudip is offline
post #4 of 11 (permalink) Old 12-10-2011, 05:26 PM
mackyoudip's Avatar
Or just scroll down on this website to the tire height calculator
competitiondiesel
Mack: 2004 lb7
post #5 of 11 (permalink) Old 12-10-2011, 07:19 PM
Using Macky's formula and throwing in 55 for the sidewall ratio, you come up up with 33.20866. Using the website Mack posted, it calculates to 33.21. Are you measuring the tire loaded on your truck? Would it make a difference measuring a tire & rim combo loaded on the vehicle versus off the vehicle laying flat on the ground?
2008 Chevy LTZ CC/SB
EFI DSP5 SPADE
Profab EGR delete / Profab DP
4" MBRP
Transgo Jr
PCV reroute
Insight CTS
Line X Bedliner
JPD298 is offline
post #6 of 11 (permalink) Old 12-10-2011, 09:46 PM Thread Starter
I measured them on the truck.
post #7 of 11 (permalink) Old 12-11-2011, 10:02 AM
Thatmarkguy's Avatar
competitiondiesel
Here's another website that you can compare the difference between your present or stock tires and another size and how they will affect your speedo.
Miata Tire Calculator
2011 Chevrolet Silverado 2500 HD LTZ Crewcab Duramax/Allison
DPF Delete, MotorOps Tuning, Corsa Muffler
5000K HID Light Kit, Fass 150 Lift Pump
305/55/20 Cooper Zeon LTZ
Thatmarkguy is offline
post #8 of 11 (permalink) Old 12-11-2011, 10:32 AM
mackyoudip's Avatar
Just realized that this has a 55% sidewall not 50%...
Oops!
Mack: 2004 lb7
post #9 of 11 (permalink) Old 12-11-2011, 10:37 AM
mackyoudip's Avatar
Weight of the truck makes them shorter.
Mack: 2004 lb7
post #10 of 11 (permalink) Old 12-11-2011, 12:33 PM
melon16's Avatar
the best way to measure the acutal size is to measure horizontally not vertically. the weight of the truck will make the tire squish and make it shorter.
My cooper zeon 305/55/r20's measure about 32 7/8"
The height of the tire will change slightly with the width of the rim as well. and 8" wide rim will make the tire slightly "taller" than a 10" one.
08 LMM "LEFTY" MBRP 4" turbo direct, Danville 3794 II, Idaho Rob DSPS5, Airdog 2 165, "SS" bumper, egr blocker, Cobalt guages, AEM meth injection, Merchant Automotive MA700 built trans, Ion Alloy 183's with Cooper Discovery H/T 275/60/r20 (33"), DJM 6" control arms and custom 4-link bagged rear
1/8th: 8.13 @ 84.1mph
melon16 is offline
