Sponsored by Discount Tire
Old 07-29-2009, 11:43 AM   eBay Motors   #121 (permalink)
dordtrecht5
dordtrecht5's Avatar
James, only out of curiosity do I ask this question. I had an alignment done at the stealership and they leveled the truck side to side. The guy that did the alignment said that the truck seems higher than a normal truck. As a regular cab and I think it is a W/T model, if not just an LS, I am wondering if these trucks come out of the factory a little higher than the EC and CC models. If so, what size of tire could I go with as far as height is concerned without rubbing? I have no lift or level kit. If you need pictures with a tape measuring distances I could do that just so you know for sure. I am going to stick with the 265/75 right now, I am simply curious.
Dallas Crist
2006 Chevy 2500 HD LBZ RCLB 4x4
6" BLACK stack; CAI; PPE Lift Pump; PCV Reroute; PPE Tie Rod Sleeves; EGR Block Plate; TransGo Jr.; Stanadyne Performance; Amsoil;
Best 1/4 13.41@102.8 (early summer '09); Best 1/8 8.09@87 (Fall '09)
EFILive by Husker Diesel: name that tune--DallasCleanHotv.1
Got Cheese? Work RAT!
dordtrecht5 is offline   Reply With Quote
Old 07-29-2009, 03:05 PM   eBay Motors   #122 (permalink)
TYREBOYZ_DEMAXIN
Diesel Addict
i noticed that the RC,EC trucks and earlier HD trucks sat higher then the CC and the newer ones! i noticed that they dropped in hieght when the LLY came out! not sure why though!
i have run 35's on a few of the older ones and cleared them with only the T/Bars raised and slight trimming!
James
TyreBoyz Pulling Team
Business Truck
DD/Beat Around
Economy Saver
Old 07-29-2009, 09:02 PM   eBay Motors   #123 (permalink)
dordtrecht5
okay, thanks....that put my curiosity to rest then.
Dallas Crist
Old 09-30-2009, 01:46 AM   eBay Motors   #124 (permalink)
eyecatcher01
eyecatcher01's Avatar
i am going to be needing new tires sometime this winter and curious what size i can get away with. i have bfg ta ko's 285/75/16's currently and thinking about going with 305/70/16's. they measure the same as the 285's but wondering if would need a spacer or if they will even fit on my factory 16's.
07' lbz, cc, sb, cobalt pyro/boost on post, downpipe back mbrp 4'', diablo predator, 285/75/16 mickey baja claws. fuel rail shim kit and new fuel filter...not installed yet
eyecatcher01 is offline   Reply With Quote
Old 10-15-2009, 08:31 PM   eBay Motors   #125 (permalink)
jstncse
jstncse's Avatar
Looking to install BR Goodrich 285-75R-17 KM2's
Tell me if 285-75r-17 tires will fit under a 2009 GMC 2500 with a cognito 2-3" a-arm leveling kit cranked to the max. the 285's are 33.8"???????
jstncse is offline   Reply With Quote
Old 10-21-2009, 05:45 AM   eBay Motors   #126 (permalink)
steakman
steakman's Avatar
A number of posts ago, someone asked that if by going to a larger tire, which in turn would effectively change the gear ratio, would it not also be true that one could expect better mileage.?
The answer in my opinion should have been yes and no. And all depending upon how you drive and whether it is all hwy, 50/50 mix or mostly city.
@ hwy 90+% I am going to have to say that yes generally speaking, you will get better mileage. 50/50 one would likely break even or get slightly less and if you are mostly city driving it will likely get worse.
The culprit is in fact larger diameter and weight. Where on the hwy, once you have that tire in motion, it will not require any (or at the very most very little), extra power to keep it going and even if so, not so much that it will overcome the extra distance travelled per revolution of tire.
My truck is levelled and I drive 265/75R16 michelins..am on the hwy mostly 90+% of the time and I do in fact get better mileage than stock. Typically about 2% better. (107kmh or 66mph).
As an FYI, those of you going to larger tires, keep in mind that by simply cranking your T bars, although it will definitely get your front end up, it will also change the angle on your upper ball joint big time. If you plan on leaving it that way and driving it for any length of time, those ball joints will in fact fail along with some other items as well. You may wish to consider new UCA's with bolt in ball joints from Cognito and adding proper length shocks or shock extenders.
Dont ask me how I happen to know that..
stk
06 LBZ CCSB SLE Blanco
Tricked just a bit - All MOds in the Garage
152,365 miles
Preferred Diesel Performance Shop..??
Oakville, Ontario
CANADA..eh
steakman is offline   Reply With Quote
