| DuramaxForum n00b Join Date: Nov 2011
| 38x13.5x18 |
| | eBay Motors #12 (permalink) | |
| Quote:
| | eBay Motors #13 (permalink) |
| Junior Member Join Date: May 2012 Location: Pearland Texas
| im running a bds 7" on 37/13.5- 20 and they rub. Im not cutting on my truck.. I think it will look ok but cramped in a wheel well. Post pics when done
__________________ 08 LMM CC 7" BDS Lift 37x13.5-20 |
| DuramaxForum Veteran Join Date: Jan 2010 Location: Washington, Mi
| Another forum but check out this guys truck. The CC was his second truck with the setup. Diesel Place : Chevrolet and GMC Diesel Truck Forums
__________________ 07.5 3500 CC/LB | Cognito | Fuel off-road | Toyo | S475 SDP Twins | PPE Stage 5 | Apline | EFI Live | Extra Large Fender Mod Sold 02 2500HD EC/SB Duramax -EFI Live/AIRraid intake/4" dual exhaust -6" Fabtech lift w/cognito arms/braces/tie-rods -20x12 Fuel Hostage Black w/ 35x12.50x20 Toyo MTs |
| | eBay Motors #15 (permalink) |
| DuramaxForum Veteran Join Date: May 2011 Location: Columbia, South Carolina
| I have a 6 inch with 37s. I had to trim and wouldn't want 38s unless I had a bigger lift, gears, and a beefed up front end. When I had 35s my truck felt more useable offroad. After my 37s wear down, which are brand new I'm lowering mine down and putting 35s back on
__________________ TYLER LB7 2500 HD LT 6" ZONE, Cognito UCAs, 37" Toyo MTs, 22" Fuel Hostage EFI Live by ATP, Edge Insight CTS, S&B intake, Pro-Fab turbo mouth piece, PPE boost valve, Alligator CAT adapter, 5" Diamond Eye exhaust, 6" MBRB tip |
| | eBay Motors #16 (permalink) |
| Senior Member Join Date: Jul 2012 Location: Orlando FL
| Why not go 44s while you're at it? It'll help compensate for whatever else you're feeling short on haha |
| | eBay Motors #17 (permalink) |
| Needs a S.A.S. Join Date: Feb 2009 Location: Buckhannon,West Virginia
| Mine has 35's stock with minimal trimming, so 37's should clear easy with a 6 inch lift.
__________________ Reger Black on Black 05' Silverado 2500 HD 4X4 CC/SB, LBY7, LT. 8580 lbs Built motor/Trans and tuned by Blackout Performance Engine- LB7 block, keyed crank and cam, LBZ rods, cut LB7 pistons, ATI damper, MA pushrods, MA motor mounts, LML man., new guts in heads, blocked, re-routed, Bills custom intake Trans- PPE stage V Suncoast 1057 converter Exhaust- 3" D.E. dp, 4" MBRP, 5" RBP tip Suspension- Leveling kit buried, 3 rear springs added, Moto Metal 956's, 35's Steering- Cognito braces, Cognito sway bar links, P/S cooler, straight centerlink, Rare parts tie rods Interior- Wilson cell amp, Galaxy 73V, Boomer 400 linear, scanner, bluetooth 2011 30' Puma KDBSS |
| | eBay Motors #18 (permalink) |
| Duramax Forum Supporter Join Date: Feb 2009 Location: santa clarita ca
| Sawzall can make anything fit
__________________ 08 lmm efi live 530 rwhp s&b intake 5in turbo out exhaust. home made lift pump holley 150. 6 in atlas in rear custom 4 link 14 travel straight axle aam 03 dodge 4:56 gears rear locke. 37 toyo mt's 17 fuel hostage wheels rbp grille Replica recon smoked lights ppe hid lights soon to be mike l tranny |
| | eBay Motors #19 (permalink) |
| But my 06 i had 6 in lift 38 looks way better when bumper is cut and u do nor cal large tire mod tires fill the fender well
| | eBay Motors #20 (permalink) |
| Junior Member Join Date: Apr 2012
| 35 inch Toyo Open Country M/T's. Done. |
