Nitto or Duratrac - Page 3 - Chevy and GMC Duramax Diesel Forum
Sponsored by:
post #21 of 39 (permalink) Old 12-05-2012, 08:45 AM
Had my Duratracs on for about 5k miles. Still look brand new.
2011 Silverado CC LML LTZ Z71
Backup camera, LTZ Plus Package
Edge Insight CTS, Cognito Leveling Kit, Rough Country Steering Stabilizer, Goodyear Duratrac 275/70/18
SOLD 2005 Silverado CC LTZ, Z71, 6" Lift, Toyo Open Country 35"s
If you can read this,thank a Teacher. If you can read this in English,thank a Soldier.
yngbld32 is offline
post #22 of 39 (permalink) Old 12-05-2012, 08:58 AM
graymond1212's Avatar
Duratracs have had both they wear better
Sent from my DROID RAZR using AutoGuide App
2008 LMM ECSB LTZ 5"MagnaFlow, EFI Live Idaho Rob, EGR Plate, PCV Reroute, TransGo Jr
2005 LLY Crew- Sold
II S366 / EFI Live dsp5 Idaho Rob / BT Dieselworks Built Trans / Bunch of other supporting mods /
graymond1212 is offline
post #23 of 39 (permalink) Old 12-05-2012, 09:27 AM
Originally Posted by sam805 View Post
ok, now i have gotten a good price for toyo mts. You guys think 33 x 12.50 r18 will rub on a leveled lml on factory alloys?
It might be close, but i ran 305/65R18 (which converts to 33.6x12R18) bfg on a leveled 2011 so yours should fit. I also had 285/65R18 trail grapplers, and they did wear excessivly fast. i got maybe 25000 km out of them.
'11 LML 2500, Cognito 8" Lift, H&S Mini w/ Korys 200, MBRP 5", AFE Intake, EGR Deleted, Lift Pump, 3" Downpipe and modded up-pipe.
kreklevich is offline
post #24 of 39 (permalink) Old 12-06-2012, 07:14 PM
Hey guys I have a stock 2011 3500 and want to run the Duratrac 296/65/18 or or the 275/70/18 will either of these work? I do not want to level the truck at this point.
Thanks in advance
2011 Sierra 3500 SLE Extended cab 4x4
PPEI Tuned including trans
Flo-Pro cat/dpf delete pipe
S&B Dry Intake
urea tank removed
Air Dog 165
leveled with Cognito UCA's, Pitman & Idler steering braces
295/65/18 Duratracs
CTS Insight with turbo timer
55w 5000k HID
makito is offline
post #25 of 39 (permalink) Old 12-06-2012, 07:53 PM
Chevytuff19's Avatar
Thanks in advance
I doubt the 295's will fit without some fender modification...my tires required some beating on the inner fender and I cranked my torsion bars up a little.
The 275's should be fine with no lift or fender mods, though.
2011 GMC 2500HD Duramax Z-71 CCSB SLE
S&B Dry Cold Air Intake
Ranch Hand Front and Rear Replacement Bumpers (Ridgid Dually Lights on Rear (2)), NFAB 6-Step Nerf Bars, RKI Tool Box, Custom Headache Rack w/ Ridgid Dually Lights (4)
Limo Tint All Around w/ Limo Brow
EDGE CTS Insight, Rancho Steering Stabilizer, Backup Camera
3/4" Lift via Torsion Bars (it was all I could get with stock keys), 285/65/18 Nitto Trail Grapplers
GoLight Stryker HID
XRT Pro on Tow with 4" Flo Pro Exhaust
Chevytuff19 is offline
post #26 of 39 (permalink) Old 12-06-2012, 11:15 PM
Diesel II's Avatar
85K as of now on a set of Duratracs. Could go another 5K however with the snow upon us I think it's time for a new set. No complaints - not too noisy and they handle well.
Rotate about every 15K and keep the pressures up - I have found that even a 5# pressure difference can be felt dramatically. Usually keep 55 up front and 60 in the rear and that seems to handle and wear well.
Won't go wrong with a set of these.
2008 CHEVROLET DURAMAX/ALLISON CC SB Z-71 LTZ !!
Jack-It Shock Mounts, Torsion Bars Cranked, Custom Single 5" Chrome Stack, Resonator Removed, BANKS SIX-GUN w/PDA, BANKS TECHNI-COOLER, BANKS RAM-AIR w/SUPERSCOOP, Air Dog II 165, DPF and DOC Delete, PCV Reroute, Weathertech Side Window Deflectors, Ventshade Sunroof Visor, 4" Nasta Stainless Steps, GM Toolbox Setup, Work Truck
Diesel II is offline
post #27 of 39 (permalink) Old 12-07-2012, 07:33 AM
eddie's Avatar
I'm running Nitto Terra Graplers on a 2008 with 20's leveled and have gone thru three sets in 36,000 miles. I'm going to switch to another style/brand.
2008 GMC 2500 EXSB SLT Duramax 6 Spd Allison 4X4
eddie is offline
post #28 of 39 (permalink) Old 12-07-2012, 07:39 AM
suttert's Avatar
why are you running them for the 3rd time if they get that bad of milage...
Trey
01 gmc sierra slt crew cab 4x4 6.6 dmax, efi live by Idaho Rob,
315/75/16 Goodyear Duratracs on 16" Moto Metals,
3" body lift, 5" Diamond Eye straight pipe with 7" tip,
Z Series Autometer Boost and Pyro, 6k Highs 8k Lows and 3K fogs, tinted windows
cat adapter and donaldson filter, adII
horn intake mod, tinted tails, lots of plasti dip
led interior and dash lights, retros led reverse lights
Big thanks to ATP TRUCKS and ALLIGATOR PERFORMANCE
suttert is offline
post #29 of 39 (permalink) Old 12-07-2012, 07:47 AM
eddie's Avatar
I guess I'm a slower learner , the first two sets were a different compound. I switched on the last set and it felt like I was driving on ice while towing. I called the tire shop back and they said it would go away after 1,500 miles. It did, but they still wore very fast. I like the looks of them on 20's, but the cost is getting out of hand now.
I'm checking out the Goodyear Duratrack's right now, found the 285/60/20's for $356 at tire rack so it doesn't appear they are any cheaper. If I get 40k out of them I'd be on could nine.
I was looking at Toyo Open CT AT 285/55/20 at $337.99, anyone used them?
eddie is offline
post #30 of 39 (permalink) Old 12-07-2012, 11:27 AM
I deal heavily in tires and have owned both Dura tracs and Trail Graps on my Duramaxes. I personally prefer the off road performance and look of the Trail Grapplers. Unfortunatley the wear on them is fast, I run quite a bit of high way and off road as I spend Sept-May hunting for birds and big game every year. I wore my Mud Graps out in about 22k miles (1 hunting season). Also the Mud Graps are absolutley TERRIBLE with side to side snow pack/ice traction (they grab just fine moving forward or backward) on snow packed roads.....especially towing trailers. I regularly pull a car hauler and a 16ft enclosed tandem axle trailer packed to the gills with goose decoys and hunting gear. BOTH are great over all off road performers from shooting fowl in muddy corn fields to spring turkey and fall white tail in the muddy creek bottoms to climbing in 2 ft of snow chasing rocky mountain elk and mulleys. The Dura Tracs perform quite a bit better on Ice and hard packed snow. As for mileage the Dura Tracs are FAR superior, yeilding at a minimum 15k more than the Mud Graps. The one and only reason I do not run Dura Tracs (this may sound stupid) is the fact that I dont like the way they look, I prefer an aggresive tire with a very bold and square shoulder, the Dura Tracs are just too round on their shoulders.
I spend most all of my time some where on this planet hunting some sort of game, the rest of my time is wasted-Abe
06 G.C. SRT-8 Black-sold
93 GMC Typhoon pearl white-high 11s/low 12s
06 G.C. SRT-8 Inferno Red-sold
05 Silverado Crew Cab Durmax-Hunting Rig
04 Sierra SLT Durama-Sold
04 Silverado Duramax-Sold
turbotyphoon69 is offline
