| Junior Member Join Date: May 2012 Location: Saginaw Michigan
| Rubbing Question I'm going to be getting a 6" Zone Lift, Green Keys, and an add a leaf. Will 20x12, -44 offset Fuel Hostages with 35 Toyo MTs fit? Does anyone have this same rim and tire package? I don't care to do a little trimming.
__________________ 2006 Silverado 2500 HD EC/SB, LBZ, 4WD EFI live by Duramaxtuner, MA Tierod sleeves 6" Zone 20x12 Fuels 35" Toyo M/T, MBRP dp, 5" MBRP stright piped to 7" tip DMAXSTORE.COM, Your Duramax Diesel- Only Shopping Resource |
| no one has this setup?
| Junior Member Join Date: Aug 2010
| i have this set up with 20x12 fuel octanes and with some trimming and turning up your keys you can make them fit. When my 35's wear out i might go with 37's so you should be alright.
__________________ 2001 black chevrolet duramax ex cab 4x4 exterior: 6 inch zone lift, 20x12 black fuel octane rims, blacked out grill and bumpers, readylift leveling keys, superchips programmer performance: 5 inch MBRP turbo back straight pipe exhaust, programmer soon to come ... DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| OK thanks Sent from my DROID RAZR HD using AutoGuide.Com Free App
| Senior Member Join Date: Oct 2012 Location: Celina, TX
| im not running the same wheel and tire package but have the same suspension setup and i run 37s with a 18x10 -25mm offest, but u should be ok with running a 35.
__________________ 2004 lb7 ccsb 4x4. Efi live tuned by Rob at ATP, ARP head studs, tie rod sleeves, cognito traction bars, airdog 165, ppe boost valve, turbo horn, s&b cai, LML driver side manifold, cat fuel filter adapter 1r-0749, installed cab lights and tow mirrors. NBS back seats. 6 inch zone offroad lift lowered down and running 305/55/20, optima red tops, Mbrp 5 inch turbo back straight pipe exhaust. Soon to come: Built trans, Built motor, and twins http://www.trollperformance.com/ |
