| Senior Member Join Date: Mar 2010 Location: Ottawa, ON Canada
| TPMS reset for lower pressures (D Rated) - Done I have been running D rated duratracs (currently 315/70/17) on my truck for over two years now and while I was at the dealership the other day to reset the TAPS on my built trans I had the tech I knew reset the TPMS at 50 PSI so they will only go off now below 43 and above 57 PSI. Less than $50.00 for the TAPS reset and TPMS fix with the tech II. Money well spent not having to scroll through the DIC 8 times a day when I get in and out of my truck for the low pressure warnings.
__________________ 2008 LMM CCSB Black on Black SLT Z71 4-6" Cognito NTBD Lift - HD Tie Rods -All Steering Upgrades - Traction Bars Downpipe - SS Exhaust All Season/Dirty Hooker Diesel Built Trans EFI Live with DSP5 (tunes by IdahoRob) - AIRDOG II 165 Gauges - EDGE - INSiGHT CTS Thanks to Tim @ TNE Diesel. |
| Junior Member Join Date: Jul 2010 Location: Stewartstown, PA
| That's good info to know. I have the same problem but I was worried that the dealer might screw up my EFI Live tunes if they changed anything on the ECM. Let us know if you have any issues. Thanks
__________________ 07.5 GMC LMM SLE2, Z71 ECSB, ReadyLift 2" Kit, EFI Live-Autocal DSP5 by Idaho Rob, Magnaflow 4" downpipe back stainless exhaust w/DPF delete, Banks Ram Air Intake w/Super Scoop, Airlift 5000 Airbags w/In-cabin controllers, Retrax Tonneau Cover, Shocker Train Horns with 5 gallon on-board air and Viar Compressor, Bilstein 5100's, Line-X Bedliner, Mickey Thompson Baja ATZ's 285/70/17, Pulling Cedar Creek 36RE Touring Edition 5th Wheel, B&W Turnover Ball w/Companion Hitch |
| DuramaxForum Veteran Join Date: Sep 2011 Location: Ontario, Canada
| I need to do this with mine. Hate having to press the dic button everytime as well Sent from my iPhone using AutoGuide.com App
__________________ 07.5 LMM ccsb ltz 8 inch fabtech lift,36x15.50 baja mtz's,20x12 fuel nutz,colour matched,reflexxion hood,x-metal grille,s&b cai,8k hid's,dsp5 by Kory Willis,mbrp 5 inch with mbrp dp,7" black chrome stack,PPE boost and pyro gauges,edge insight cts,bd blow off,egr delete,pcv re-route, alpine touch screen, 2 10" type r's ![]() http://www.alligatorperformance.com |
| No issues with EFI Live... I am running it as well. They do not reflash the ECM. I was sure to ask before they hooked up the tech II.
| Junior Member Join Date: Apr 2012 Location: Mooreton, ND
| Quote:
__________________ 2009 GMC 2500 CC/SB SLE. Interior:Weathertech floor liners, Autometer Cobalts. Exterior:6 inch Zone, 315 Duratracs on H2's, AMP steps, Duraflaps, AVS visors, Delta toolbox, Recon LED cablights, Retrosolutions LED reverse lights, All-on mod. Performance:ATP Autocal, MBRP 4 inch straight pipe, 6"x18" Rolled tip, S&B intake, EGR blocker plate, Resonator plug. Trans-go JR. and DE dp in the box awaiting install. | |
| I like them. Run them all season, they are good in the snow. I got 46k - 48K miles on my 285's. Still had some life left but it was winter so I changed to some new 315's. Probably going to get close if not a little more on my 315's as I rotate them more often. Into them for about 30k miles now and still good life left. Rotation and pressures are key to long life in an AT or MT tire for sure.
__________________ 2008 LMM CCSB Black on Black SLT Z71 4-6" Cognito NTBD Lift - HD Tie Rods -All Steering Upgrades - Traction Bars Downpipe - SS Exhaust All Season/Dirty Hooker Diesel Built Trans EFI Live with DSP5 (tunes by IdahoRob) - AIRDOG II 165 Gauges - EDGE - INSiGHT CTS Thanks to Tim @ TNE Diesel. Last edited by Black 2500; 11-28-2012 at 07:06 AM. |
| | eBay Motors #7 (permalink) | |
| Quote:
| | eBay Motors #8 (permalink) | |
| Quote:
I know my 315's are 50 PSI max. I am running 48 -50 in my 315's now. I found my mileage suffered when I went down to 42-44 PSI.
__________________ 2008 LMM CCSB Black on Black SLT Z71 4-6" Cognito NTBD Lift - HD Tie Rods -All Steering Upgrades - Traction Bars Downpipe - SS Exhaust All Season/Dirty Hooker Diesel Built Trans EFI Live with DSP5 (tunes by IdahoRob) - AIRDOG II 165 Gauges - EDGE - INSiGHT CTS Thanks to Tim @ TNE Diesel. | |
| Okay cool. What you getting for mileage pulling the 315's deleted and all?
| was at 17-17.5 city and 20 hwy. built trans about two weeks ago and now down to 15.8 city and only hwy has been hauling trailers. Winter blend fuel they use here also drops me about 1 mpg over the colder seasons.
