Wheel Bearings - Page 2 - Chevy and GMC Duramax Diesel Forum
Sponsored by:
Old 01-17-2013, 01:03 PM   eBay Motors  #11 (permalink)
werewolf's Avatar
What had happened was!!
Not a bad job at all though. Just did mine a bit back. I got a really bad squeak when turning to one direction and it was annoying. Checked it out and it was shot. Definitely need a big torch wrench and a 36mm as stated
2006 2500HD GMC Sierra SB/CC
Diamond eye down pipe,5" MBRP straight pipe exhaust
PCV reroute EGR delete
Nicktane Adapter W/ Donaldson filter
PPE standard level 3
PPE Race Fuel Valve Ported Fuel Rail Fitting
werewolf is offline   Reply With Quote
Old 01-17-2013, 01:09 PM   eBay Motors  #12 (permalink)
The shaft actually provided pre-load to the bearings and keeps them part of the unit. Without the shaft the two bearings will push themselves out of the units and the whole works come unglued in a most spectacular way. Best thing to do if your shaft goes is to cut the outboard boot and pull the end of the shaft off and leave it in the hub, you can pull the rest of it out to stop the binding but leave the outboard stub in.
2008 2500HD LTZ, EFI Live- Idaho Rob's Tunes, 4" Magnaflow Turbo Back, Raptor 150 Lift Pump, Transgo Jr, All Season Diesel EGR delete with high flow Y-bridge, Edge Insight for gauges,
ironman_gq is offline   Reply With Quote
Old 01-17-2013, 01:39 PM   eBay Motors  #13 (permalink)
rms
rms's Avatar
^^^ I think one of the guys here actually removes his cv axles when traveling cross country.
He replaces them with an old stub and the 36mm nut (don't know how he torques it down).
Apparently, the mpg increase is worth the effort.
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/75/16 Cooper ATP's - 8' Bedslide
Amp Steps - Bilsteins - Fumoto
rms is offline   Reply With Quote
Old 01-17-2013, 01:47 PM   eBay Motors  #14 (permalink)
boostnlb7's Avatar
that is very possible.. like stated you can cut the boot and leave the outer on.. thats all it needs to hold the bearing together.. so yes you can travel all over with the outer part of the shaft still in and the nut on.. in his case he would torque it down as usual, the splines in there will stop it from turning when tightening
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is offline   Reply With Quote
Old 01-17-2013, 01:48 PM   eBay Motors  #15 (permalink)
boostnlb7's Avatar
[QUOTE=werewolf;1906712]What had happened was!!
the gol darn wheel fell off on me!
Old 01-17-2013, 02:23 PM   eBay Motors  #16 (permalink)
blacksmokelb7's Avatar
I WOULD NOT DO THAT!!!!!! Had a guy on DD took his axels out for summer within 3000 miles he was replacing the front wheel berings.Depending on who made your hubs, some hub makers depend on the side presure to keep the bering tight and support it.take that out and next thing you know the wheels are laying over.
Sent from a black cloud and the smell of burnt rubber.
04 CCSB LB7 IIs483 over IIs366,carillos,cut and coated lb7 slugs,ported heads,RDL downpipe uppipes manifolds ,efi live with dsp5,Big Dipper stage 4,4 inch out the back, ram air keystone hood,US Speedoo fox racing shocks cluster,rolling on hummers,and wraped in silverbirch. And some wicked tunning from Bo-Bo (Bob Olson)
11.64 @117
Originally Posted by hllbllylmsne
Sounds like you screwed up the seat to steering wheel linkage, no real fix for it, sorry
blacksmokelb7 is online now   Reply With Quote
Old 01-17-2013, 02:23 PM   eBay Motors  #17 (permalink)
Oops guess I should have read this before posting
11.64 @117
Old 01-17-2013, 06:31 PM   eBay Motors  #18 (permalink)
Where is a good place to go get a wheel hub at and whats a fair price for one?
topcat is offline   Reply With Quote
Old 01-17-2013, 08:51 PM   eBay Motors  #19 (permalink)
rms
rms's Avatar
It looks like the Dmax Store with the Kryptonite warranty (lifetime) at $199.00 is the way to go.
Old 01-17-2013, 08:53 PM   eBay Motors  #20 (permalink)
rms
rms's Avatar
Lol - right, with the tire on the ground. For some reason, was thinking of the thing on a jackstand.
