| DuramaxForum n00b Join Date: Feb 2011 Location: Cecil
| Wheel Bearings I have an 03' Dmax and looking at replacing my front wheel bearings, and I was wondering if the front wheel bearings need to pressed in or is it a wheel hub bearing assembly |
| it is an assembly.. no pressing, just 4 bolts and the abs wire.. its not a bad job at all..
| DuramaxForum Enthusiast Join Date: Apr 2012 Location: Pittsburgh Pa
| Pretty easy change out.
__________________ 2006 2500 HD SLT ECLB, LBZ, Bilstein shocks,Banks 4inch exhaust, Alligator Adp Cat filter. And S&B air intake good to be driving a diesel again. 2002 Chevy silverado 2500 HD, LB7, traded it on a gasser and then traded it in for LBZ. |
| 20120921_115510.jpg dont forget to put c.v axle in or damage could be caused.. this one is a long story, there was no forgetting the shaft..
| Oh...... Squirrel! ![]() Join Date: Oct 2006 Location: Irwin PA
| Ya there simple. If you have a air compressor you might want to pick up a cheap air chissel and a spade bit. Also, youll need a pretty big socket to take the hub off. 36MM or 38MM IIRC? This place has the best deal on them IMO Timken Bearings (NEW + Kryptonite) [SP580310-SP580311-580312-58013] - $199.99 : DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource Quote:
__________________ Jason ![]() 2006 Silverado 2500HD LBZ CC SB Exterior: Escalade Handles, Front windows tinted to match the rear, painted bumpers & mirrors, billet grille, 285/70/17 Nitto Crossteks on Pro Comp Wheels, Cognito Braces, Stainless Sleeves, Train Horns Interior: 4 Kicker 10in Subs in 2 custom box's, Autometer Ultra lite II Pyro and Boost gauges, Aeroforce Interceptor Gauge, HID Lows & Fogs, Painted accents Performance: EFI Live Tuned by Blackout Performance, Custom Blackout Performance S475 over stock twins, 45 over stock injectors, MBRP Turbo Back Stainless Exhaust (Straight piped), Raptor Lift Pump, AFE Filter, GMAX6 kit with Suncoast 1057 converter installed by Blackout Performance 1999 Ford F-550 PowerStroke ''Wrecker'' **Jerrdan bed, S&B Intake | |
| Junior Member Join Date: Apr 2012
| Timken hub, 36mm socket and a good half inch torque wrench that goes to 250. Torque is 177 if I remember right. Easy enough job for sure. |
| | eBay Motors #7 (permalink) | |
| Junior Member Join Date: Sep 2009 Location: CAPE COD,MASS
| Quote:
__________________ 07 classic ext cab 6"skyjacker 35x13.5x18 efi by rob thanks to SPECIALED09 ![]() transgo jr, ml converter, pcv reroute, ported egr, s&b, AD165, shimmed rail,turbo blocker plate, insight cts,kryptonite,supersteer,homemade water meth in the works, probably some i missed CAPE COD COAL ROLLERS | |
| | eBay Motors #8 (permalink) | |
| Quote:
shoulda known though, ended up doing it all on the side of the road..
__________________ couldnt pass hazing to be a "pup bro" ![]() 03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos- auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel | |
| I bet the hub got fouled up when the shaft broke. It went unnoticed until wheel fell off.
